Lincoln II+ programming
163TM847
Post by 163TM847 »
Quick question as i cannot find the answer by searching, But am I right in thinking the L2+ cannot be programmed with different frequencies on a particular band like the Anyclones? IE: UK1-40 on Band D
PS: I have tried manually changing frequencies on a band and that doesn't work.
ChubbyChops
Call Sign: 26TM773
Re: Lincoln II+ programming
Post by ChubbyChops »
Yes that's correct.
I save 27,601.25 as a memory channel then just go up from there. but the channels don't line up so you have to learn the frequencies for each UK channel.
Also means you can't scan the full UK 40 channels either, but that isn't what the radio was designed for.
