East Midlands Ambulance
- liamcarbin
Re: East Midlands Ambulance
Is there a limit to the amount of filters I can have? I've tried creating a filter "999" but when I press ok it doesn't appear in the filter list.
Liam Carbin
Stoke-on-Trent
Uniden Bearcat 3500xlt
Realistic Pro-70 Hyperscan
Moonraker Skyscan Mobile Antenna
R820T Dongle ADSB Receiver
TYT-MD380
Stoke-on-Trent
TYT-MD380
- archspoofer
liamcarbin wrote:Is there a limit to the amount of filters I can have? I've tried creating a filter "999" but when I press ok it doesn't appear in the filter list.
I don't believe there is. I have 4 filters in at the moment and it runs ok. Is it possible you clicked the wrong button
Age and knowledge don't always come together. Sometimes you just get the age...
I have 11 filters in place at the momentliamcarbin wrote:Is there a limit to the amount of filters I can have? I've tried creating a filter "999" but when I press ok it doesn't appear in the filter list.
Are you wanting every message containing the numbers 9 9 9 as in the emergency phone number?
I dont think I`ve ever seen any message come in containing a tripple 9 before now
when you add the filter you have to remember to select if you its a flex capcode or pocsag riccode or text amongst other options, you should choose text, enter your filter in the text field then click ok
26TM234
- liamcarbin
Example - 999 (05/09 15:40) @ ON THE BOULEVARD NEAR TO THE BUSES, 45 Market Gatessmoggy07 wrote:I dont think I`ve ever seen any message come in containing a tripple 9 before nowliamcarbin wrote:Is there a limit to the amount of filters I can have? I've tried creating a filter "999" but when I press ok it doesn't appear in the filter list.
Shopping Centre, GREAT YARMOUTH, NR302AX. 10 Chest Pain (M COLLAPSED).
871 enroute (1.0 ml). Ref:550
I've done exactly what you said, ive selected text, entered it and then pressed ok, but nothing happens.
Very strange.
May have a workaround for myself, ive added it manually in the filters config file.
Liam Carbin
Stoke-on-Trent
TYT-MD380
Stoke-on-Trent
TYT-MD380
- archspoofer
smoggy07 i see your profile says ur near the coast. If there is a RNLI station nearby might be worth a try on 153.075 as "Apparently" this is assigned to RNLI as Data.
liamcarbin wrote:Example - 999 (05/09 15:40) @ ON THE BOULEVARD NEAR TO THE BUSES, 45 Market Gatessmoggy07 wrote:I dont think I`ve ever seen any message come in containing a tripple 9 before nowliamcarbin wrote:Is there a limit to the amount of filters I can have? I've tried creating a filter "999" but when I press ok it doesn't appear in the filter list.
Very strange.
I tried to add 999 as a filter but it didnt work for some bewiltering reason but I have a work round
make a new text filter and in the text box enter the word police and hit ok, when you see the filter "police" in the filter window, double click it and change the word police to 999 and hit apply (its at the bottom between the ok button and the cancel button), then click ok to go back to your filter list and it should be there
26TM234
I have this as well as many other freqs in my "pagers" scan list on my pcr 1000 and have never seen anything relating to the RNLI, where I am at the moment (I`ve moved from a noise hell hole in town to a partial dead spot closer to the hills but also closer to the coast) but I will give it a watch thougharchspoofer wrote:smoggy07 i see your profile says ur near the coast. If there is a RNLI station nearby might be worth a try on 153.075 as "Apparently" this is assigned to RNLI as Data.
26TM234
- liamcarbin
Even adding police....still nothing.
Must not like me
Liam Carbin
Stoke-on-Trent
TYT-MD380
Stoke-on-Trent
TYT-MD380
Can you add any text filter that is not numbers or is it being funny with all filters? try duplicating a filter you already have in your list then edit it or double click on one of the filters already in your list, change it to 999, hit apply then re-add the old filter you edited, if that makes senseliamcarbin wrote:Even adding police....still nothing.Must not like me
26TM234
- liamcarbin
That will have to be the way then, I can add a duplicate but I cant add any new filters from scratch. Thank you for your helpsmoggy07 wrote:Can you add any text filter that is not numbers or is it being funny with all filters? try duplicating a filter you already have in your list then edit it or double click on one of the filters already in your list, change it to 999, hit apply then re-add the old filter you edited, if that makes senseliamcarbin wrote:Even adding police....still nothing.Must not like me
Liam Carbin
Stoke-on-Trent
TYT-MD380
Stoke-on-Trent
TYT-MD380
Hi, sorry for the late reply but I just wanted to ask are they still using these frequencies today?archspoofer wrote: ↑08 Feb 2011, 22:32 Anyone been picking up East Mids Ambulance via Pocsag 153.325 mhz ???
Been getting them for ages no problems.
Around 14:00 hours today their messages just stopped. Rather weird, still getting everything and everywhere else just not EMA messages.
Any ideas anyone??
The missus says they have seen the forum & changed everything LOL WOMEN
- archspoofer
It would appear not, I assume they are now utilising the capability of the tetra system to handle data, however it seems loads of ambulances in the Manchester area still use the old systems and are able to be decoded on POCSAGKraynor wrote: ↑15 Jul 2022, 17:31Hi, sorry for the late reply but I just wanted to ask are they still using these frequencies today?archspoofer wrote: ↑08 Feb 2011, 22:32 Anyone been picking up East Mids Ambulance via Pocsag 153.325 mhz ???
Any ideas anyone??
