Marine yagi connector or balun
yagiman
Post by yagiman »
Dear forum members
I have a yagi marine aerial
But the bit that holds the coax connector
Is it called a balun
Re: Marine yagi connector or balun
Post by ch25 »
And?
yagiman
Post by yagiman »
You’re and didn’t make sense
Post by ch25 »
When you connect balanced antenna to unbalanced feeder you should (must) use a balun.
