Babyloop mast ?
nordhavn
Babyloop mast ?
Post by nordhavn »
How deep would you recommend burying/planting a 2" pole for a babyloop ? It's only 2m above ground but the loop weights 16kg . The ground where it will be situated is fairly soft .
Re: Babyloop mast ?
Post by ch25 »
Depends on wind speed in you area.
nordhavn
Re: Babyloop mast ?
Post by nordhavn »
ch25 wrote: 02 Jan 2022, 15:17 Depends on wind speed in you area.
50+ mph in winter .
Re: Babyloop mast ?
Post by ch25 »
1m deep, concrete filled hole would be more than enough.
