DSD+ and RAS
NR641_uk
Call Sign: NR641
DSD+ and RAS
Post by NR641_uk »
I am trying to learn how to program a Kydera unit on DMR. I have the software and can read / write an manage analogue channels fine.
In order to work out how to program DMR channels using the software I obviously need to avoid those systems using RAS as the radio will stay silent. I have an Airspy R2 and use DSD+ which enables the CC & TG to be seen. Having had a go using this info my radio stubbornly remains silent! Is there a way of being able to tell from DSD+ if a system is employing RAS and if so how is it displayed in the various DSD+ windows.
Any help would be great before I tear the remainder of my hair out!
AirSpy R2 / Yaseu VR5000 / AOR DV-10 / Yupiteru 9000 / 7200 / Motorola Handie Pro / Kydera DR880UV
And some Baofeng junk!
Mototrbo2020
Re: DSD+ and RAS
Post by Mototrbo2020 »
Will say (RAS) on the window that shows the CC.
Metradio
Call Sign: G7HID
Re: DSD+ and RAS
Post by Metradio »
A DMR transceiver will also stay silent trying to receive a DMR repeater if the TX and RX are programmed to the same frequency..
Mike
Mototrbo2020
Re: DSD+ and RAS
Metradio wrote: 17 Dec 2021, 23:43 A DMR transceiver will also stay silent trying to receive a DMR repeater if the TX and RX are programmed to the same frequency..
Mike
And to add to that it's the same if the CC SL or TG do not match.
NR641_uk
Call Sign: NR641
Re: DSD+ and RAS
Post by NR641_uk »
Many thanks for the suggestions, got me all sorted now.
Metradio
Call Sign: G7HID
Re: DSD+ and RAS
Post by Metradio »
NR641_uk wrote: 18 Dec 2021, 15:13 Many thanks for the suggestions, got me all sorted now.
What was the solution then ?
Mike
NR641_uk
Call Sign: NR641
Re: DSD+ and RAS
Post by NR641_uk »
Once I put both the TX AND RX frequencies in then everything came good. Previous to that I had them as the same. Many thanks Mike :-)
26mb04
Call Sign: 26DG01
Re: DSD+ and RAS
Post by 26mb04 »
Isn't RAS merely a tx flag to instruct the receiving radio to ignore the transmission unless it has a matching RAS code? Technically, a DMR scanner could break the protocol and ignore RAS flags, but it mightn't be possible on a DMR-compliant rig.
Sent from my GP300 using DTMF
Metradio
Call Sign: G7HID
Re: DSD+ and RAS
Post by Metradio »
26mb04 wrote: 21 Dec 2021, 20:19......a DMR scanner could break the protocol and ignore RAS flags, but it mightn't be possible on a DMR-compliant rig.
That's how it works.. Some DMR scanners are better than others at ignoring RAS :)
Mike
