I am trying to learn how to program a Kydera unit on DMR. I have the software and can read / write an manage analogue channels fine.
In order to work out how to program DMR channels using the software I obviously need to avoid those systems using RAS as the radio will stay silent. I have an Airspy R2 and use DSD+ which enables the CC & TG to be seen. Having had a go using this info my radio stubbornly remains silent! Is there a way of being able to tell from DSD+ if a system is employing RAS and if so how is it displayed in the various DSD+ windows.
Any help would be great before I tear the remainder of my hair out!
DSD+ and RAS
- Call Sign: NR641
DSD+ and RAS
AirSpy R2 / Yaseu VR5000 / AOR DV-10 / Yupiteru 9000 / 7200 / Motorola Handie Pro / Kydera DR880UV
And some Baofeng junk!
Re: DSD+ and RAS
Will say (RAS) on the window that shows the CC.
- Metradio
- Call Sign: G7HID
Re: DSD+ and RAS
A DMR transceiver will also stay silent trying to receive a DMR repeater if the TX and RX are programmed to the same frequency..
Mike
Mike
- Call Sign: NR641
Re: DSD+ and RAS
Many thanks for the suggestions, got me all sorted now.
- Metradio
- Call Sign: G7HID
Re: DSD+ and RAS
What was the solution then ?
Mike
- Call Sign: NR641
Re: DSD+ and RAS
Once I put both the TX AND RX frequencies in then everything came good. Previous to that I had them as the same. Many thanks Mike :-)
- Call Sign: 26DG01
Re: DSD+ and RAS
Isn't RAS merely a tx flag to instruct the receiving radio to ignore the transmission unless it has a matching RAS code? Technically, a DMR scanner could break the protocol and ignore RAS flags, but it mightn't be possible on a DMR-compliant rig.
Sent from my GP300 using DTMF
- Metradio
- Call Sign: G7HID
Re: DSD+ and RAS
That's how it works.. Some DMR scanners are better than others at ignoring RAS
Mike
