SWR for PMR 446
ChubbyChops
Call Sign: 26TM773
SWR for PMR 446
Post by ChubbyChops »
I've built my own antenna for PMR but I don't have a SWR meter that covers 446, so is there any way you can use a standard HF CB meter, or do I need to buy one specifically for UHF?
Cheers
Re: SWR for PMR 446
Post by ch25 »
You need UHF meter.
I would buy NanoVNA instead.
ChubbyChops
Call Sign: 26TM773
Re: SWR for PMR 446
Not sure I'd know how to use that lol
Re: SWR for PMR 446
Post by ch25 »
Pretty simple. There are a lot of tutorials on YT, it shows SWR as any other meter plus some more important parameters when you build your own antennas.
SWR is least important parameter when building antennas. R, jx, RL are crucial. You won't see them when using simple SWR meter.
ChubbyChops
Call Sign: 26TM773
Re: SWR for PMR 446
:thumbup: Thanks mate. I'll check YT
Bigpimpy
Banned
Banned
Call Sign: P1MPY
Re: SWR for PMR 446
Post by Bigpimpy »
if you have a through type meter it will work fine up to 150Mhz and may give a suitable reading at VHF.
or use a field strength meter and adjust for maximum RF.
I want to die asleep like my Grandad did,
Unlike his passengers, Screaming and Shouting.
ChubbyChops
Call Sign: 26TM773
Re: SWR for PMR 446
Bigpimpy wrote: 06 Dec 2021, 10:06 if you have a through type meter it will work fine up to 150Mhz and may give a suitable reading at VHF.
OK, cheers for the suggestions.
