LBA Frequency update
neil57uk1
Re: LBA Frequency update
Post by neil57uk1 »
453.100 is not a Ground freq. It's used infrequently by the fuelers so not busy.
Mitch0113
Post by Mitch0113 »
Ok thank you is there any other frequencies I will be able to listen to like ground staff or anything else my frequencie range is around 145mhz - 480mhz
AMX97
Post by AMX97 »
Hey last time I was around the airport was said that it was ground staff it was one of the more active frequencies that day I'm nkt 100% sure could have been changed or may have just been a issue with display on scanner honestly couldn't say
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
Baofeng UV-9R
uniden ubc125xlt
Moonraker M10
