Tetra decoder- any activity ?
gmham
Call Sign: 108TM154
Post by gmham »
Fancy trying out a tetra decoding software with my rsp1 / sdr# but before I do is there much unencrypted tetra signals around the Fife / Edinburgh area ?
What type of user uses tetra over DMR ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Metradio
Call Sign: G7HID
Re: Tetra decoder- any activity ?
Post by Metradio »
Non Airwave Tetra tends to be used by a number of underground railway systems i.e. London Underground, plus a tram system in Nottingham...
Don't think there is anything around Fife/Edinburgh..
Mike
gmham
Call Sign: 108TM154
Post by gmham »
Okay cheers Mike maybe won’t bother then ! To be fair out with the emergency services you don’t hear a lot about it so you.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
elliotg
Post by elliotg »
I work security at a few of the Covid Test Sites in Edinburgh and we use Hytera radios i'm not sure but are they TETRA radios?
Whistler TRX-1
Metradio
Call Sign: G7HID
Post by Metradio »
elliotg wrote: 08 Mar 2021, 08:42 I work security at a few of the Covid Test Sites in Edinburgh and we use Hytera radios i'm not sure but are they TETRA radios?
Doubt it, Tetra is designed for expensive multi slot trunked radio systems, a bit over the top for event security..
Hytera make all sorts of radios, they have a model designation on them, from that we can identify mode and frequency band..
Mike
jhampton2000
Post by jhampton2000 »
As Mike says, I very much doubt it's TETRA either. Switch it off, pop the battery off for a second, have a look at the model number, tell us what it is. It'll likely say frequency band as well. I'm willing to bet it'll be a PD5 or PD7 model. A TETRA subscriber model will be a PT model.
elliotg
Post by elliotg »
Sorry guys wrong radio completely we use Sepura SBP8340
Whistler TRX-1
Metradio
Call Sign: G7HID
Post by Metradio »
elliotg wrote: 09 Mar 2021, 06:22 .............Sepura SBP8340
UHF DMR..
Mike
scottyboy
Post by scottyboy »
Possibly using simplex on Uk general or short term hire frequencies
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
