I am in the process of repairing my Trio R1000 receiver.
The rf att switch wont turn around because the aluminium shaft inside has become detached from the coupling.
Ok so I have bought some replacement coupling and a steel shaft.
My question is this, by taking out an aluminium component and replacing it with a steel one, could this interfere with the receiver's capabilities??
Aluminium V Steel
- MW0SWA
- Call Sign: MW0SWA
Aluminium V Steel
I am a bit crazy about the Realistic DX-394
- Farty
Re: Aluminium V Steel
Provided the switch functions in the same manner there should be no difference.
