How can you tell if a Sepura is clear?
- radiogaga
- Call Sign: 26TM399
I know that the MTH800 have the word clear on the label, how would you tell if the SRP2000 is in clear mode?
30TM399 Northern Costa Blanca
- TRON
Re: How can you tell if a Sepura is clear?
* 4 7 7
Tab 6
"0/0 NON" means clear
Tab 6
Interested in Tetra and other digital modes?
http://www.youtube.com/user/digitalradiohacker
http://www.digitalradiohacker.co.uk/
- radiogaga
And what about whether it whether it's TG ?
- TRON
Not sure what you mean?
- radiosification
I think he means what talkgroup it's on.
- TRON
I'm not sure if explaining the inner workings of mobile network identities is what is REALLY wanted here...
Have you got a problematic terminal that refuses to talk to other terminals? Are you trying to solve some sort of problem?
- radiogaga
Sorry guys been away... I mean. On the Motorola 850 there is a suggestion that he rear label should show "CLEAR" to make it a realistic purchase. Is the Sepura the same?
This explains it all though...TRON wrote:* 4 7 7
Tab 6
- TRON
I haven't noticed any relationship between labeling and encryption on the Sepura's. There MAY be an indication, but I've never noticed it.
- radiogaga
Great - Thanks. Just would be easier if something cropped up on the bay ..
My understanding is that on the label there is a hardware code (H/W Code)
On my srh3800 it is PS9TG001T400G00
Now the 4th and 5th characters (T and G) is the frequency band TG = 400-433mhz
The main frequency bands in use that you see for sale is TT = 380-400mhz, TW = 380-430mh, TZ = 410-430mhz, TG is listed above, UO = 440-473mhz and TS = can't remember exactly but I think around 360 - 400mhz
The 6th character is a number which represents the encryption originally in the handset.
In this case the number is 0 which means clear.
If it was 1 it would be TEA1. So if mine was TEA1 the H/W code read PS9TG101T400G00
2 would be TEA2 etc
Hope this helps
2 would be TEA2 etc
Hope this helps
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- radiogaga
Makes good sense.. Thanks for that
