Hi Guys,
I've been tinkering with my Baofeng MKII and have stumbled upon something that's confused me. A search doesn't reap any results.
Under option 19 in the menu, there is a function named "Pri" which I presume is priority - I've set it to "on".
On other bits of radio gear I have, Priority momentarily checks Channel 1, but on this UV-3R it isn't.
Can anyone please shed any light on this or tell me what the default priority channel is, if any?
UV-3R MKII "Priority" query
- Warden
- Call Sign: 26TM612
Re: UV-3R MKII "Priority" query
It's whatever memory channel you choose. You might have to set that via software, and the pri feature did not work on a lot of older models.
26-TM-612
No one rules if no one obeys.
Winner of the amazing In before the lock game 09/09/14
Neither of my MK2s even have memory option 19.
- toby
- Call Sign: 513
hi,
i don't remember how to chose the priority channel. i think i did that with the software.
if done, you can guard three frequencies: https://www.youtube.com/watch?v=XELDQWW92Wc
Thanks a lot guys.
I've programmed everything manually as opposed to using software so this explains the problem.
I'll get the cable and software and get this sorted asap.
- Warden
26-TM-612
