I have a Derby TS1000 ( Uk FM straight 40) i use in the car as its nice and small to fit in these modern cars, however it stopped transmitting and a TO-220 part stamped “ KA1276Y” has a crack in it so assuming this is the culprit.
Not much info out there on my radio so would anyone know what the ”KA1276Y” is - is it a voltage regulator as never come across that part before, normally the regulators i have seen have been the 7808 type so thought i ask you knowledgeable chaps on here. The part doesn’t seem readily available from what i can see so is there a replacement readily available part I can use instead?
KTA1276Y has blown
- timbob58
- Call Sign: 26tm957
Re: KTA1276Y has blown
Think you can use the ( TIP42 ), pinout is the same and it is a voltage regulator
Thanks timbob, i will get a TIP42 and try it.
- Call Sign: 26TM773
There's a complete spare radio here https://www.ebay.co.uk/itm/154617239483 ... SwyNNhRxo8
Just ordered the tip41 so hopefully this should fix it, so will pass on another one at this stage chubbychops, but cheers for posting this.
- timbob58
,,,, 41 or 42 ?thoroughbreed27 wrote: ↑26 Sep 2021, 10:22 Just ordered the tip41 so hopefully this should fix it, so will pass on another one at this stage chubbychops, but cheers for posting this.
Had a senior moment and ordered a tip41 - doh!!!oh well i will order the correct part now, now i have more ordering experience!!!
Ordered right part after my senior moment, Put a TIP42C in and yay i have transmit again, thank you for the steer it works a treat!!!!!!
