superstar 360 making strange noise
- yogibear2781uk
- Call Sign: 26tm343
superstar 360 fm
my superstar 360 has not been used for about a year ....
and i got it out the cupboard and set it up ......
turned it on and its making a strange noise (like its being some one is keying up and de keying very quickly )
it transmits perfect on all bands......
any one got any ideas as what to check please......
superstar 360 fm mk2 , cobra 148 gtl dx mk2 , ham international jumbo , president mckinley , harrier cb x2 ,
harrier cbx x8 , harrier cbhq , harrier wt1 2channel handheld , harrier wt2 40 channel handheld , uniden 100 & 200, plus loads of other cb's
- cb4ever104
Re: superstar 360 making strange noise
Does it happen on all modes ?
- yogibear2781uk
yes all modes the same
- cb4ever104
Does reducing the RF gain reduce the noise ?
- yogibear2781uk
still the same and ive disconnected the antenna and still the same
- cb4ever104
Sorry . Does the S meter move up and down in line with the noises ? Maybe posting a video might help .
S.
S.
- cb4ever104
Also . Tighten all the screws that hold main pcb to the chassis .
- yogibear2781uk
have tightened all the screws and no the signal meter is not moving
ill try video it a bit later
- cb4ever104
OK . Does it actually receive incoming signals on the selected band/frequency ?
S.
S.
- yogibear2781uk
yes got good signals
- cb4ever104
Final question from me . Does the noise increase or decrease when the volume is adjusted ?
- 13EL121
- Call Sign: 13DA121
Maybe a blown electrolytic capacitor?
- yogibear2781uk
no it stays the same
- 13EL121
Maybe a photo of the inside would help. A blown cap in the audio section could cause this.
- cb4ever104
Looking at all the symptoms , it definitely looks like a fault around the audio amp . As Ralf says it may be a bad cap . Or it may be the audio amp itself . A scope would be your best friend just now . If you don't have one then check the voltages on the audio amp anyway . I presume it's mkII 360FM ? If so , then here's what you should have .
