Commtron Cxx / Nat0 F.M capacitance issue
hallo
I have one of these but it looks like i need to add a litle more capacitance to the VCO to get it bang on frequency across the 3 bands
(US1-40, US+1-40, UK1-40) It reads as follows for example:-
26.965 is actually reading 26.966?
27.60125 is actually reading 27.60180?
My frequency counter is calibrated but to be on the safe size i checked it on my other rig and it read 27.60125 exact.
No adjustment of the relevant CT trimmer will get the values any lower, it will incresase in frequency ok but won't tune down any lower than this.
Could anyone tell me the ID for the capacitor I need to experment value wise with please?
Thanks!
Thanks!
- Otter
- Call Sign: 26TM439
Re: Commtron Cxx / Nat0 F.M capacitance issue
C212 and C245 are the capacitors that set the frequency of the 10.240 reference. Only look at the 26.965-27.405 frequencies when adjusting the reference. After that there is a separate trimmer for hi band, and seven trimmers to cover the UK frequencies.
I will try some different capacitors and see what it does, may try a new ct pot if the capacitors dont work. Will let you know how it turns out, thanks for the help!
- bigpimp347
have you checked the 10.240 is right ??
i sold a couple of these radios due to being a pain to set up and no information out there..
i have a XII on 10mtrs i want to put back on 11 but nothing out there to help me figure it out so it's sat in the junk box.
- Otter
There's a schematic. It's just another LC7120 Maxon chassis. There's an extra wafer on the channel switch which selects one of 7 crystals in the right place when it's in on the UK band. There's also a standard 15.810 for high band. If you need / want the schematic pm me your email address. If someone has removed the UK crystals you will be looking for another scrapper to get them from.bigpimp347 wrote: ↑01 Apr 2021, 15:03 i have a XII on 10mtrs i want to put back on 11 but nothing out there to help me figure it out so it's sat in the junk box.
X401 is 15.810MHz and adjusts the Hi band.
These are the Xtals and the UK channels that will change when you adjust them
Xtal UK Channels Xtal Freq
X402 1-3 15.99625 MHz
X403 4-7 15.98625 MHz
X404 8-11 15.97625 MHz
X405 12-15 15.96625 MHz
X406 16-19,24,25 15.95625 MHz
X407 20-22, 26-40 15.94625 MHz
X408 23 15.92625 MHz
- Otter
Wait - you said XII not CXX. That should just have a couple of extra crystals for low and high - 14.910 and 15.810. Nothing special.
- bigpimp347
that's the thing it's a normal maxon board but the crystal board isn't like a CXX/Nato board,
also it's half it's size, only has one crystal currently on it and some pleb has disabled low and hi band off the band switch.
so i need to repopulate the crystal board, which i should be able to do but also reinstate the band switch,
but i'll look at it again one day..
if you need any mic inserts let me know i'l PM you a link to a really good 600ohm insert that fits tight.
- Otter
600 Ohm inserts link would be great. Thanks for that. Isn't the Commtron XII the same as the Colt 510? There's a schematic on cbtricks for that.
Its sorted!!!
changed the 56pf (C212) to 100pf and its bang on now across everything, would have been back sooner but had to order the capacitor needed. Thanks for the help its been great!
- Call Sign: 26TM773
Hi All
I need a mic insert for one of these (Commtron CXX).
Would appreciate the link too.
Also need to start with getting it working again.
It's totally dead except for the PA circuit.
Any ideas?
Any ideas?
- Otter
The first thing to do is check for the correct voltage (roughly 7.8V) on the PLL chip pin 16. Then check for 10.240 oscillation.
Pin 16 is showing 0.2 volts.
All other pins on PLL are 0 volts.
Just a quick thank you for the info on this thread.
I've got mine working and on frequency using the info posted here.
I just need to peak the TX circuit but still need a mic insert @bigpimp347 if you wouldn't mind letting me know where to get them from please.
Thanks again chaps.
Thanks again chaps.
Does anyone have the receiver alignment procedure for this radio please?
Figured it out, I think.
RV101- Squelch
RV201-AM Modulation
RV501-FM Deviation (sub board)
RV103- Rx "S" Meter
RV202- Transmit Rf Meter
TX - L304, L305, L306, L303, L302, L301. L306 peak then anticlockwise to 4.0w
RV201-AMC, D203--AMC Defeat
RX - L204, L101, L102, L103, L104, L105, L106, L107
FM detector on sub board next to case.
RV101- Squelch
RV201-AM Modulation
RV103- Rx "S" Meter
