New expansion - UPD858 SSB chassis
- New User
- Call Sign: SM3TEK
Re: New expansion - UPD858 SSB chassis
Hello Sue. Thanks for answering my mail..
This is the expansion I was refering to in my mail..
Could not send an PM to you didn't have the privileges to do it..
Hope this is okey..
Best regards
//Lars Lindberg
Hope this is okey..
Best regards
//Lars Lindberg
- Call Sign: KN6OZW
This is truly an amazing design! As I am new to Aurduino and Adafruit, I do not as yet have the ability to create a sketch for the Audrino to control the Adafruit. The board is built, installed and I'm all ready to go... Except for the firmware/software. Do you have a link for the sketch you made for the Audrino and do you have a link for the Windows software you created for tuning the radio?
Thank you in Advance!
"Rookie" Audriono user,
Dan
KN6OZW
Dan
KN6OZW
- cb4ever104
Hi Sue .
Could you send me the hex and exe files for this one please .
- cb4ever104
Decided that I'm going to install one of my Adafruits into my old 858 GRANT . I'm going to recap the radio first , but once I've done that then I'll start this installation . I'll post updates here as I go along .
S.
S.
Will do. Away on a road trip at the moment, will email or cyberlocker them to you when we get back Monday or Tuesday. Recap is essential with those first, yet to see one that didn't have at least bad electro...
- cb4ever104
Thanks Sue. Think I already have all the info and files. I'll keep you posted.
If you can't find them, PM or email and I'll send a link to them in the reply.
- cb4ever104
My basement is still in the mid 30s , so I'll start this project once it starts to cool down a bit
- Stronty
Something like this sprung to mind when I read thatcb4ever104 wrote: ↑26 Aug 2022, 07:32 My basement is still in the mid 30s , so I'll start this project once it starts to cool down a bit
I've had this thread bookmarked since it started and I was very interested when @dt307 did the Adams, would have loved to see a finished article on that one.
All those valve and Spark Gap Transmitters Paul........ Toasty
- cb4ever104
Might be able to do that Dougie with one of these
This expansion is more or less the same as the 2824 one which I did previously . There's a few differences in the value of some of the components , but the gist is the same . It's just to hot here at the moment to do anything . It's times like these when I wish I was back living in Yoker
- Call Sign: charlie62
Salve puoi inviarmi lo sketch per arduino, e se puoi il link dell'app rf20. Grazie.
Hi can you send me the sketch for arduino, and if you can the link of the rf20 app. Thank you.
Reason: translation
Reason: translation
- Call Sign: AMC45
What would be needed to do a 12 band 158? The one with hi lo bands switch as its has two xtalscb4ever104 wrote: ↑26 Aug 2022, 09:43Might be able to do that Dougie with one of these
Not sure what you mean be a "158" - many brands and models we never seen down here in Oz, so you'll need to give enough detail to allow a meaningful google or document search. Brand and full model name, and what PLL chip / crystals it has in it should be enough to say yes or no.
Also, "12 band" - is that 12 x 450KHz (i.e. 12 lots of 40 channels, aka 5.4 megs of coverage, like 24.6 to 30 MHz)? If the radio was designed for a lot less than that originally, it's going to need some creative broadbanding before you start.
- Call Sign: AMC45
It’s the ranger ept9900 14blbcomms wrote: ↑24 Nov 2023, 22:53Not sure what you mean be a "158" - many brands and models we never seen down here in Oz, so you'll need to give enough detail to allow a meaningful google or document search. Brand and full model name, and what PLL chip / crystals it has in it should be enough to say yes or no.
Superstar 158fb4 12x40ch six way band switch with hi lo toggle button
I’d have to check the xtals
Those are very rare down here, can only recall records of doing one in 10+ years, and that was for a routine repair, not a modification.
At a minimum, we would need a schematic, the crystal frequencies, and the downmix frequencies (N-codes) for channel 1 and 40 on each band.
On the plus side, no need for broadbanding mods, looks like it was designed in the first place for that bandwidth...
