Ay up all.
Been searching high and low for these in the UK and I cannot seem to get them anywhere. Does anyone know of a UK supplier?
Cheers.
Psi
The infamous MV1Y diode varistor: where to buy in the UK?
- PsiDOC
- Call Sign: 163FKU
*Proud owner of a Cornflake Packet Amateur License and registered instructor in the art of gaining said license*
Icom IC-756 Pro III
Yaesu FT100D.
President Washington
President Adams
Tait T2020 70mhz
Baofeng UV-5R 2m / 70cm
Icom IC-756 Pro III
Yaesu FT100D.
President Adams
Tait T2020 70mhz
- cb4ever104
Re: The infamous MV1Y diode varistor: where to buy in the UK
Clint !
Sammy
Sammy
- Call Sign: 30LO3589
Re: The infamous MV1Y diode varistor: where to buy in the UK?
And somebody knows where to buy in europe or spain?
- Otter
- Call Sign: 26TM439
Something to watch out for is that the ones for a Lincoln MRF477 have the pins swapped vs the ones for a Cobra 148 and most other radios.
- cb4ever104
Just use a 1N4001. There's been lots of discussion on here about them in the past. There's also a video on YouTube that discusses them. The result of that test was that the MV1Y was just a normal diode in a different packaging.
S.
S.
- Otter
If a diode is to be of any use it will have to have good contact with the transistor. It needs to heat up with the transistor to protect it.cb4ever104 wrote: ↑16 Mar 2021, 09:02 Just use a 1N4001. There's been lots of discussion on here about them in the past. There's also a video on YouTube that discusses them. The result of that test was that the MV1Y was just a normal diode in a different packaging.
S.
- 13EL121
- Call Sign: 13DA121
I had a Magnum S9 in for repair, replacing all bipolar finals (original 2SC1969). Magnum used 1N4001 diodes in the circuit too...
