Guide to replacing Signal meter bulbs with LED's
1968neil
Re: Guide to replacing Signal meter bulbs with LED's
Post by 1968neil »
LEDs can be dimmed but you’ll need to use PWM.
(Pulsed width modulation)
Basically varying the duty cycle with a pot is all that’s needed if you use a small microcontroller.
I’m happy to knock up a circuit and software if anyone is interested in having a go ?
Neil
