EFHW 49:1 antenna setup advice
Jim444444
Post by Jim444444 »
Decided to try out this configuration as it'll fit in my garden and can use a tree branch half way up for support.
The antenna is 124 ft long and covers 80-10m
Has anyone tried a similar configuration also was wondering how high off the ground should the end point of the antenna be.
Re: EFHW 49:1 antenna setup advice
Post by ch25 »
EFHW is bad and problematic antenna, but still better than no antenna.
Just hang it.
https://www.w8ji.com/long_wire_antenna.htm
