Charging a bricked MTH800
rlf79cm
Post by rlf79cm »
Further to last post, I've managed to get the Flasher tool working to repair the MTH800. Problem now is the battery is dead..!
Does a bricked MTH800 charge? Doesn't seem to take charge from the standard charger and my SPN1772A is also faulty so won't charge off the main port of the spare battery one. Only thing I can really think of is to buy another MTH800 and charge the battery off that one?
Alan Pilot
Re: Charging a bricked MTH800
Post by Alan Pilot »
Can't see why it won't charge it should.
rlf79cm
Post by rlf79cm »
Yes it's very odd. The radio has a flash image and codeplug on now but the versions don't match - radio can still be read in CPS. I've got the correct versions to update it now but as soon as it connects via Power/1/9 it says battery voltage 1.26v and shuts down.
I've ordered a replacement battery and charger so hopefully that will fix it.. I just wasn't aware if the mismatch of flash and codeplug would stop it charging :?:
scottyboy
Post by scottyboy »
If different versions of codeplug for firmware then it won’t work.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
26mb04
Call Sign: 26DG01
Post by 26mb04 »
Can you not charge it manually, if you can work out the battery pinouts? I know it's super dodgy, but it might be worth a shot if you're up the creek. I suppose M have stopped that for Safety now, and for battery/charger sales.
Sent from my GP300 using DTMF
