Hello everyone,
im new to this forum, so i hope its the right place for this topic.
I get an SRH3800 with terminal programmer 6.3.3, so far so good.
This is my first tetra radio and i hope anybody could help me.
If i start reading out the radio then the soft is testing the parameter sets, after 96% testing there pops up an error ....shown in the pic
"read parameter index size mismatch
parameter index 3370 is 1 in size
radio reports parameter 3370 is 400 in size
The process will now terminated"
Does anyone knows what that means and could give me a hint how i can read and write the parameter in the radio correctly?
Thanks very much for your help
Alex
Sepura SRH3800 Pragramming HELP!!
- TRON
Re: Sepura SRH3800 Pragramming HELP!!
I haven't used Terminal Programmer in years, but I think the problem you are having is that the radio has newer firmware in it than your software can deal with.
In all likelihood, that radio was last programmed with Radio Manager, and you'll probably need Radio Manager to write to it now.
Where abouts are you? UK?
Interested in Tetra and other digital modes?
http://www.youtube.com/user/digitalradiohacker
http://www.digitalradiohacker.co.uk/
He must have sorted it and doesn’t need help after all
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
