Motorola Codeplug wanted
- Call Sign: MW7GIA
Re: Motorola Codeplug wanted
Im having the exact same issue. I've PM'd you also PeakHour, bit cheeky i know but im at my wits end.
Expensive paperweight at the moment
- Call Sign: MW7GIA
- Werthers
Just to clarify a codeplug isn't the programming software. They are two different things.
You need the appropriate Motorola CPS programming software for your radio, a blank code plug can be found within the programming software or easily created using the Motorola CPS.
What programming software are you looking for?
I've got the CPS for DM and DP radios but the software didn't come with blank code plug for the DP4400 on UHF as my boss bought a bunch used and it turned out they had passwords on but the seller was adamant there wasn't any and we couldn't get a blank code plug to write to it
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
uniden ubc125xlt
Moonraker M10
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
uniden ubc125xlt
Moonraker M10
cick recover. voila. blank non passworded radio.AMX97 wrote: ↑18 May 2021, 19:55 I've got the CPS for DM and DP radios but the software didn't come with blank code plug for the DP4400 on UHF as my boss bought a bunch used and it turned out they had passwords on but the seller was adamant there wasn't any and we couldn't get a blank code plug to write to it
HELLO CAN ANYONE HELP ME ??? I have motorola dp4400e and try to use cps 16 (823) cps v 2.0 newest version but i cannot connect with my device because showing message codeplug device not supported ....???? how can i sort this out ?? thank You guys for any help .. my email is [email protected] if anyone got this codeplug and can send it to me....
- Tittifer
I've read all this thread and i still don't know what a codeplug is
- bigbloke
A codeplug is a small file of radio configuration data, that is generated on a computer using
the customer provisioning software , then transferred over a cable (usually a serial cable) into the radio
for the purpose of configuring that radio to be used in a given radio system.
if you're more familiar with computers, think of it more like a windows .ini file or linux .conf file
Hope that helps
regards
BB
Hi everyone ive got the CPS software the latest version from RadioTronics but when trying to read from the DP4400 i get a pop up saying #101005 not supported any ideas
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
uniden ubc125xlt
Moonraker M10
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
uniden ubc125xlt
Moonraker M10
- Tittifer
Thanks BB I think I get it nowbigbloke wrote: ↑27 Oct 2021, 16:50A codeplug is a small file of radio configuration data, that is generated on a computer using
Hope that helps
regards
BB
- New User
HI!
I have the same problem with a motorola DP4400e VHF.
I have a codeplug, i can read from the radio it, but that's corrupt.
If I entry more as 2 channels the radio dont't work.
I hope the problem it's only the codeplug, but i'm not sure...
Can pls anyone send me a new sample codeplug for this radio?
THX
Siegfried
THX
Siegfried
Just recovery it in cps.siegfried wrote: ↑06 May 2022, 15:15 HI!
THX
Siegfried
- New User
Hi, Thx for your's reply!
Unfortunately the recovery function does not work, it displays: error, can't find the recovery file for the connected device.
have anyone a sample codeplug pls?
I've searched it in the cps sample codeplug folder, but there are no sample codeplugs for dp4400e VHF.
Help!
Siegfried
In that case you will need to download a blank one that goes with your Firmware version and then recover it.siegfried wrote: ↑07 May 2022, 16:56Hi, Thx for your's reply!
Help!
Siegfried
