Kenwood TK-361
BroadsBen
Call Sign: 26TM109
Kenwood TK-361
Post by BroadsBen »
Hi Guys,
Don't suppose anyone would have a copy of an instruction manual for a Kenwood TK361?
I have just been given a couple of hand sets and although the frequency's are the same the CTCSS codes appear to be different.
Any help is appreciated!
Ben
26TM109
Spike
Re: Kenwood TK-361
Post by Spike »
Cant find a manual off hand but this should help.
Code: Select all
    * TK361 SRBR
    * 1 - 461.2625MHz - 94.8Hz - Same as Red 1 Motorola
    * 2 - 461.4750MHz - 88.5Hz - Same as Green 1 Motorola
    * 3 - 461.4875MHz - 103.5Hz - Same as Yellow 1 Motorola
    * 4 - 461.4750MHz - 79.7Hz - Kenwood only
    * TK361 T2 PMR446
	Ch1	Ch2	Ch3	Ch4
	446.00625MHz	446.09375MHz	446.03125MHz	446.06875MHz
1	94.8Hz	88.5Hz	103.5Hz	79.7Hz
2	107.2Hz	110.9Hz	114.85Hz	82.5Hz
3	118.8Hz	123Hz	127.3Hz	85.4Hz
4	131.8Hz	136.5Hz	141.3Hz	91.5Hz
5	146.2Hz	151.4Hz	156.7Hz	179.9Hz
6	162.2Hz	167.9Hz	173.8Hz	192.8Hz
7	132DCS	155DCS	134DCS	243DCS
8	311DCS	346DCS	315DCS	351DCS
9	423DCS	664DCS	431DCS	723DCS
    * Changing Programmed CTCSS/DCS Tones
    * Switch OFF the radio
    * Press and hold PTT and LOW (button under PTT) then switch ON the radio
    * Select the CHANNEL you wish to program its CTCSS/DCS code
    * Press MONI (2nd Button under PTT) repeatedly until you have selected the desired CTCSS/DCS code
    * Press LOW (button under PTT) to confirm settings
    * Cycle Power OFF then ON to use the new settings
    * An increasing number of beeps indicates the chosen tone, 1 long beep = 5 short beeps (9 Max as per above table)
    * Changing Programmed Frequencies (i.e. channel position has different SRBR/PMR446 channel attached to it NOT other non SRBR/PMR446 frequencies)
    * Select the CHANNEL you wish to program its frequency
    * Press PTT repeatedly until you select the desired frequency
Ian
East Northamptonshire Shooting Association
"Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” Benjamin Franklin
"It is are not raining in Tokyo"
BroadsBen
Call Sign: 26TM109
Re: Kenwood TK-361
Post by BroadsBen »
That's Perfect, very helpful.
Thanks very much!
Ben.
26TM109
callumh26
Re: Kenwood TK-361
Post by callumh26 »
I know i'm bringing up a really old thread here, but I was wondering if anyone was able to help me program these. I'm trying to program the radio to a CTCSS tone but all i seem to be doing at the moment is changing the DCS tone or the frequency. Is any able to give any pointers?
Thanks in advance
Callum
