Motorola Codeplug wanted
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Hi all
Does anyone have a Motorola DP4400 UHF codeplug then could send me please?
Doesn't matter what is in it, can be blank, just need it to recover my 4400 which I've forgotten the codeplug password for and can't find the previous read.
Samples in the CPS are for a VHF radio not UHF unfortunately.
Cheers
30TM399 Northern Costa Blanca
moj
Re: Motorola Codeplug wanted
Post by moj »
which cps do you need it working on , i've got 12.1 codeplug here m8 if that's any use ?
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Thanks.. should be fine, using 12.5...
Can you upload to a dropbox or similar please?
Ta
moj
Post by moj »
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Top Man :P
moj
Post by moj »
no problem , let me know if it works ..
radiogaga
Call Sign: 26TM399
Post by radiogaga »
It does :) Thanks
radiosification
Post by radiosification »
I know I'm a bit late, but for future reference or for anyone else reading this thread you can usually find a folder with default codeplugs for most radios already on your computer. It gets put there when you install the MotoTRBO CPS.
radiogaga
Call Sign: 26TM399
Post by radiogaga »
It does but the DP4400 is for the VHF radio not UHF.
radiosification
radiogaga wrote:It does but the DP4400 is for the VHF radio not UHF.
Ah sorry, my mistake, I just saw that you did mention the samples in your first post. However it was only a brief mention so hopefully my post will help someone in the future searching the forum for a sample codeplug
macuser
Post by macuser »
Hallo und good evening, i need a codeplu for my DP4400 UHF. I have the same problem with the password and the same VHF codeplug in the cps.
Can anybody help me?
(sorry for my very bad english...)
Squirrely
Post by Squirrely »
moj wrote: 22 Sep 2016, 10:29 https://www.dropbox.com/sh/j4snmlm1zkuj ... Mu4Wa?dl=0
there you go mate ;)
Hey, any chance you could re-upload that codeplug? i also require a copy, thanks!
kevinbleicester
Call Sign: 26uk116
Post by kevinbleicester »
Hi, silly question is a blankcodeplug still avaailable for the DP4400 I have got a radio from ebay and it is locked codeplaug. As far as I can tell if i uploead a new codeplug it will overright the old one with no password. Is that correct? do OI need to put the radio into a special mode to do this? Thanks in advance.
scottyboy
Post by scottyboy »
Any codeplug from the same model will do. Just choose clone radio and it will overwrite the codeplug.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
