DMR (TDMA) 446
dc260
Re: DMR (TDMA) 446
Post by dc260 »
Transmission1 wrote: 06 Dec 2021, 12:20 I tried some DMR simplex on 446 recently with someone across town.
We simply used CC1, TG1 and Slot 1 across all 16 channels. Works perfect and should be easy enough for anyone to program on various models. If you're wanting to make random contacts like on analogue 446 then that's probably the best way to do it!
We have tried using DMR on PMR446 using Baofeng-DM1801 and Anytone radios on our evening net, it works very well in high noise environment, even if you are a weak signal the voice is still clear, if we could adopt using talkgroup 1, colour code 1, timeslot 1 as the standard it would help promote it even more.
I could be heard on around 1 watt over 5 miles away whilst on analog my voice was too staticy to be readable.
Also we have been staying away from channel 8 instead using channel 10 as channel 8 is the analog calling channel to avoid interference.
My website for radio and programming related topics https://decoderstar.co.uk/
My PMR446 information website https://pmr446.net/
26mb04
Call Sign: 26DG01
Re: DMR (TDMA) 446
Post by 26mb04 »
I've reprogrammed my dmr for this 446 config (it was tg99). Let's hope it takes off, digital 446 could be a larf with text messages etc.
Sent from my GP300 using DTMF
DX-Digger
Call Sign: TM205
Re: DMR (TDMA) 446
Post by DX-Digger »
Just programmed my MD380 for DPMR not dPMR as I mistakenly programmed before {bnghd}
So will have a listen around will leave it scanning
Hmm I wonder if my hotspot will move to 446MHz?
Who will be the first to set up a network like the Hams use??
:geek:
AshtonMobileScanner
Call Sign: 26TM931
Re: DMR (TDMA) 446
Post by AshtonMobileScanner »
Hey guys its already been done DMR446 Network https://youtu.be/PJXZh8R8azA
Motorola UHF DP3600,
Golden One 1907,
Baofeng UV5RA+,
Diamond RH771 Antenna,
UHF Stubby Antenna,
Diamond X-30 Antenna,
MASS SPS 250 MK2.
(Monitor All Channels)
DX-Digger
Call Sign: TM205
Re: DMR (TDMA) 446
Post by DX-Digger »
AshtonMobileScanner wrote: 23 Dec 2021, 02:18 Hey guys its already been done DMR446 Network https://youtu.be/PJXZh8R8azA
Very interesting, thanks for sharing :thumbup:
AshtonMobileScanner
Call Sign: 26TM931
Re: DMR (TDMA) 446
No problem mate
Golden One 1907,
Baofeng UV5RA+,
UHF Stubby Antenna,
MASS SPS 250 MK2.
