Cheap repeater ?
gmham
Call Sign: 108TM154
Cheap repeater ?
Post by gmham »
Seems cheap enough eh ?! Seem to remember parrot repeaters being sold before but this would probably be a better idea ?
Anyone uses similiar ?
https://www.ebay.co.uk/itm/353756839208
Icom IC746
Cobra 148gtldx mk2
Xiegu G90 HF SDR
John - 108TM154 / 108CO154
Metradio
Call Sign: G7HID
Re: Cheap repeater ?
Post by Metradio »
The cheap cross band repeaters have been around a while and once the VOX levels are set up they work well. It is advised that the 2 radio antenna are spaced out from each other as far as possible, >15ft..
I think these work on a first come first served basis, others can have a VHF or UHF priority..
They seem to work cross mode with no problems..
Mike
gmham
Call Sign: 108TM154
Post by gmham »
Thanks mike appreciate the info yes must admitt did cross my mind how the two radios would work sitting right next to each other buy yes if making a permanent or semi permanent set up you would obv try use a decent external antenna as opposed to just using the two radios with there set top aerials . Just need to find a local hill to site it !!!
Icom IC746
Cobra 148gtldx mk2
Xiegu G90 HF SDR
Metradio
Call Sign: G7HID
Post by Metradio »
An even better solution with DTMF remote control so you can activate and shut down etc..
https://www.ebay.co.uk/itm/274065554882
My testing was done on a high rise building with radio antenna separated vertically .
The most important thing is the quality of the radio receivers quality.
Mike
dc260
Post by dc260 »
If you have a raspberry pi and a USB audio card you can make use of my parrot repeater script, the repeater boxes above won't work on 446 as there is insufficent bandwidth between the channels to set up a duplex repeater. That is unless the apparatus can operate in simplex mode (Parrot).
https://github.com/decoderstar/pi_parrot_repeater
My website for radio and programming related topics https://decoderstar.co.uk/
My PMR446 information website https://pmr446.net/
