DIY HF vertical from tent poles?
26mb04
Call Sign: 26DG01
Post by 26mb04 »
Has anyone made a HF vertical from collapsible fibreglass tent poles? I have a spare length of these, I was thinking of running a wire down the middle instead of the elastic and terminating it at the base. It seems like a good way of getting height without carrying long pole sections around. I was going to use a hefty base mount so it doesn't fall over.
Sent from my GP300 using DTMF
Black_Pirate
Call Sign: 26TM034
Re: DIY HF vertical from tent poles?
Post by Black_Pirate »
Itresesting i, d keep the elastic and run a t2lt antenna made for your band... Even a carp/ kite pole is a few grams... Solid when guyed and you can run vertical, sloper or horizontal with the aid of a tree... Like that idea though..
Didi modes (JS8 on 27.245 usb) txt messages via radio lol at minus- 10 to 20 db..... 😊 See FB page...
26T.M.034
GOOD LUCK IN DX
