DIY DAB RADIO ANTENNA HELP PLEASE
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
Wanting to make myself a dipole to improve the reception on my dab radio , Can anyone please help What lenth will i need to cut the wire for this , trouble is i do not know what frequency that is used for dab radio ?
Re: DIY DAB RADIO ANTENNA HELP PLEASE
Post by ch25 »
Google know DAB frequency in UK for sure.
Does your radio have external antenna socket?
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
NO Chris it has not just a short antenna fitted
Post by ch25 »
So forget it, unless you will modify your radio with external antenna socket.
Now all you can do is to attach a piece of wire to existing antenna and hope for better reception.
Mitch
Post by Mitch »
Try a quarter wave at 31cm, UK DAB is around the 220Mhz mark, same as US ham band on 1.25m. A tiger tale could help but height is might with any radio aerial. If you're really struggling for signal put a socket on the radio and use a suitable yagi beam aerial
UK DAB frequecies:
11B = 218.640Mhz
11C = 220.352Mhz
11D = 222.064Mhz
12A = 223.936Mhz
12B = 225.648Mhz
12C = 227.360Mhz
12D = 229.072Mhz
The perfect face for radio.
TangoMike
Call Sign: TangoMike
Post by TangoMike »
mybe something like this ?
Post by ch25 »
TangoMike wrote: 18 May 2020, 08:34 mybe something like this ?
And where he will connect that?
Black_Pirate
Call Sign: 26TM034
Post by Black_Pirate »
Large bulldog clip added on the telescopic antenna weirdly worked from me in a cellar type place ha ha give it a try with a retune.. 😜
Didi modes (JS8 on 27.245 usb) txt messages via radio lol at minus- 10 to 20 db..... 😊 See FB page...
26T.M.034
GOOD LUCK IN DX
Werthers
Post by Werthers »
Build a yagi beam for it. It would be interesting to see what distant stations you can pick up. A 13 element would do. :thumbup:
MrWeetabix
Call Sign: 26TM175
Post by MrWeetabix »
I fitted a SO239 to a DAB clock radio, still have it in the shed. was amazing RX when on the colinear.
Here it is receiving some Norwegian DAB back in 2016 :-D
Werthers
Post by Werthers »
MrWeetabix wrote: 01 Apr 2021, 07:13 I fitted a SO239 to a DAB clock radio, still have it in the shed. was amazing RX when on the colinear.
:thumbup:
What colinear were you using?
MrWeetabix
Call Sign: 26TM175
Werthers wrote: 01 Apr 2021, 17:16
:thumbup:
That was with a lift on btw! haha. But I did live a mile from the sea and it was an X510 vertical.....
Werthers
Post by Werthers »
MrWeetabix wrote: 01 Apr 2021, 18:59
:thumbup:
I gathered that :D besides it be pretty amazing if there wasn't a lift on and you got that station. Being by the coast helps and the X510 antenna has a nice gain on it.
MrWeetabix
Call Sign: 26TM175
I use a comet GP-9 now and have some height. May bring it in from the shed and give it a go, see what stations I can get from here!
The GP-9’s Gain : 144 / 8.5dBi 433 / 11.90 dBi
It certainly feels lighter than the x510, that was a really heavy antenna
