Hi mate let me check, could be a plan ! Appreciate that. John
Sirio 2016 radial replacement?
- gmham
- Call Sign: 108TM154
Re: Sirio 2016 radial replacement?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- gmham
Will pm you and send you a picture of the thread etc on this one later thanks.
Edit : PM sent thanks.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- gmham
Unfortunately no joy guys different fitting on the 827 radial. If anyone does happen to have a spare radial from a scrap 2012 / 2016 please give me a shout ! Satisfy the ocd in me !!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Call Sign: 45
If you have broken radial and it is hollow tube ?. Find a long bolt, same thread as in hub.
Reduce dia of the remaining bolt that won't sit inside hub to fit tightly into radial.
You can reduce via spinning in a drill against a file.
You can protect thread needed with tape or simular.
- gmham
Okay thanks mate appreciate the advice but to be honest will just live with the missing radial unless one comes along.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
