Sirio 2016 radial replacement?
- gmham
- Call Sign: 108TM154
Help !! One of the radials on my Sirio 2016 has snapped off leaving part of the screw section of the radial within the base hub. Likely effect performance etc ? Poss to buy a replacment ?
Thanks guys.
John
Thanks guys.
John
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
Re: Sirio 2016 radial replacement?
Nearest shop with aluminium pipes. Buy as much as you need.
You won't hear lack of one radial in that case.
- gmham
Okay cheers so you say won’t effect tuning etc ? Might just leave it then, one less perch for the birds !!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
With 15 still there, nothing changes as long as you have at least 3 radials left
- gmham
Perfect thanks again.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
Blimey, would've taken one big fat pigeon to have done that
- gmham
Best of it is the antenna is not even up yet !! Was just tightening the radials to the hub when it sheared of.The Collector wrote: ↑28 Jun 2021, 18:39 Blimey, would've taken one big fat pigeon to have done that
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Call Sign: 45
That's not good, I had a couple of posts up about sirio antennas tips those who have noted issues in materials like screws heads breaking off .May be a good idea to consider better quality self tappers and look online for tips in setting the antenna up. I think we can already note a issue with radial quality.
Note - the use of a 4ft long monkey wrench to tighten up your radials may be akin to using a sledgehammer to crack open a nut
- gmham
Nope not guilty..Honest. Tightened by hand with a quick tweak of the open ended spanner !The Collector wrote: ↑28 Jun 2021, 21:54 Note - the use of a 4ft long monkey wrench to tighten up your radials may be akin to using a sledgehammer to crack open a nut
To be honest the antenna was bought used a good while ago and although it had only been up six months and in decent condition suppose these things can happen at any time. Overall I am more than happy with build quality. Have secured both joints and new screw heads with both self amalgamating tape and quality tape to help with insulation and to prevent screws comming loose thru time.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
I suppose with the wind hitting the legs and causing them to wiggle a bit, that they may suffer a little from metal fatigue, but not that much!
I think you can buy replacement legs (sure I've seen 827 ones for sale at least) and you may be able to drill out the fixing a bit and then use a reverse thread bolt extractor. I've got a cheap set I bought from Aldi or Lidl years back.
Or...not bother...or, remove every other leg so you'll be left with 8 uniform ones
- gmham
Thanks buddy, actually contacted Knights cb to ask if they sold replacment radials for the 2012 / 2016 but unfortunately not said they had tried to get them with no joy. Was mainly just to satisfy my OCD knowing one was missing !
Like the idea of removing every other leg to even things up !!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
...and as a bonus, you'll then have SEVEN spare legs, just in case any really fat pigeons DO actually sit on it and break onegmham wrote: ↑29 Jun 2021, 21:51 Thanks buddy, actually contacted Knights cb to ask if they sold replacment radials for the 2012 / 2016 but unfortunately not said they had tried to get them with no joy. Was mainly just to satisfy my OCD knowing one was missing !
Just ensure that if removing the legs leaves a hole in the base that water could get into, fill them up with clear silicone sealant. If they don't go anywhere, no need to bother.
- gmham
Okay thanks buddy good tip regards the hole left with the missing radial, the threaded but of the element is still within the base as that’s where it snapped of but great tip will just make sure that area is watertight .
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
I’ve got a load of 827 radials here don’t know if they fit…
DELETE MY ACCOUNT
