Hi all,
Just swapped my Cobra for an as new in the box President LIncoln 2 V3. On getting it home it is not putting any power out, as the rig came with no manual and is still in 10m mode, How do I do a factory re set to see if it keays up, if I get it transmitting how do you get it to 27 Mhz, don,t want to go acusing the guy of conning me if this is just a simple re set
Any help asap would be great
73
Geoff
Lincoln 2 v3 help required
- Call Sign: 163WL101
- andymuza
Re: Lincoln 2 v3 help required
Press and hold the Menu button for 2 seconds and there is a reset function in there which you select using the up down arrow buttons.
Manual is here.
Manual is here.
- Kaos
Maybe something needs snipped.
- Tinman
- Call Sign: M7TIN
Sounds like it hasn't been expanded. There's a small wire at the front of the board labelled L503 and exp that needs snipping to put it into expanded mode.
Dave
Dave
M7TIN/P
Thanks for the replies, done a re set and it still would not tx, turns out it was a bad patch lead, so its txing 100% now, just need to snip that wire now, so will whip the casings off in a bit, what frequency range will I get?
- prettypolly
- Call Sign: 26FB185
25 to 30 ish
And an ATU or a well tasty wideband twig if you plan on using all of the available frequencies.prettypolly wrote:25 to 30 ish
Wow, how easy is that to wideband, all done now and working very well, just need some good skip now. Thanks all for your help
- New User
- Call Sign: SF01scot
Re: Lincoln 2 v3 help required (new)
Is it possible to reset not using Menu button? which is not working on mine. Thank you
