Not sure if it's the right place to ask but I'm having a hard time trying to rx anything on CB. I have a GainMaster 5/8 antenna mounted at around 8 meters above ground level and all I can hear is static noise.
A couple of months ago I was able to hear 27555Khz with a horizontal dipole but now I can't with the GainMaster. Can it still be heard or the band is closed?
Unable to listen to anything on CB
Re: Unable to listen to anything on CB
There is a bit now and again.
Did you check the coax and SWR.
Try ch19 UKFM for a while to see if there's anyone nattering on there. If there is, it's probably just that SSB is a bit quiet at the moment.
Otherwise, if it's dead everywhere, is the white noise itself giving any signal or is it flat, indicating a posdible co-ax or radio issue etc (unless you have a Cobra that reads low anyway)?
As mentioned above, a SWR test should show up any problems with the aerial or co-ax.
- Alucard
- Call Sign: TW4T
I left CB years ago but kept my setup. Fired it up again I've got 7-9 pounds of crap on all channels. I put it down to the increased use of microprocessors in everything and the cheap foreign stuff that doesn't have the stringent RFI regulations required here
A horizontal antenna is less susceptible to picking up generally vertically polarized RF interference caused by the sometimes unfiltered and cheap electronic equipment found in houses, businesses and street furniture/lighting. So immediately and rather annoyingly the vertical will pick up more.
Common culprits are LED garden lighting, Plasma TV's and cheap Switch mode power supplies.
Couple that with the end of Sporadic E season and just the occasional 11m long skip opening and it is somewhat understandable.
What is your S meter reading ? A fairly solid S5-6-7-9. It will take strong signals to break through that.
- Mudslinger
Do you have of those touch lamps in your house? I have a touch illuminating globe on my desk and even when turned off it gives S7 of noise on the radio.
The only way to stop the noise is to unplug it completely.
- stanogs68
Just sit on 19 ,check all your connections your swr and hope you radio is ok. It’s not like years ago ,unless you live in Warrington lol
love your familly
The SWR goes between 1.1 on 26.5 to 1.2 on 27.9. However, I have a S7 to S9 throughout the band
The crap you're picking up (electrical interference etc from the likes of routers/wifi/transfomers/LED's etc) is probably drowning out any weak signals. At some point, you may get a strong SSB or local FM signal that'll break through it.
I take it you've tried a different radio to ensure it's not your radio playing up a bit?
Whereabouts are you by the way, in case we have someone local to you that can perhaps give you a shout?
