Monitoring on 934.
Re: Monitoring on 934.
No youre not going mad, there was and it was offered with a cb called the bluebird as i recall and they were rare back then so youll probably never find one today unless someones got one up for sale.
Its easier to find a delta 1 on ebay than try for a transverter type solution I reckon.
Did a little experimenting tonight.
With the delta connected to the co linear on C20 my noise floor here is around 3 bars, sometimes momentarily goes to 5 but most generally on 3.
Antennas fed by a length of westflex103 so I decided to see what would happen using a length of RG8 to connect inline.
Big drop off in received signal for only around 8 feet of RG8 and shows how sensitive things are at this frequency.
So if youre going to put an antenna up its imperative to use the proper cable ( moonraker supply it) and connectors or else youre just killing the signal strength.
PL259 are no good you have to use N types.
Surprised me to see such a short length do so much damage actually!
Anyways, I now have another length of westflex coming to use on the yagi, will be interested to see how it performs in respect of directionality and signal strengths.
That was kind of her.The Collector wrote: ↑24 Feb 2020, 20:09That's exactly what my wife said to me after I got her pregnant
Did a bit of further messing tonight.
Having aquired a decent swr meter for the job I tested out the co-linear. Currently reading at around 1.5:1.
Straight out of the box its pretty well on the money.
The yagi took a bit of messing to get the coax onto as its like trying to fit an angry snake onto the end of the N connector, the cables very stiff indeed.
Eventually after getting the yagi to sit and behave itself I found that the swr was 1.2:1. Im very happy with that.
Swinging it around I could isolate the local noise sources screwing up the band so at least I now can point it away from them to listen for potential voice traffic.
Continuing to monitor Ch20 and Ch 40.
Antenna still upright even after all the tornado type winds recently!
Tropo forecast for the coming week is looking fair for any traffic from netherlands, appears best on friday, so if any traffic is on there im still monitoring Ch 20 and Ch 40 , 40 being the quietest in my location.
Still monitoring daily. Have heard of a net operating in hull apparently at times.
Colinear is still hanging in there despite some pretty stiff winds the last few weeks, had to fetch it down this morning as hte inner telescoping tube had started knocking against the outer sending noise into the wall.. sounded like someone breaking in.
Couple of o rings slid down the tube and its all quiet again.
- Call Sign: 26TM123
Got quite a few 934 radios here. Might set one up again
Channel 19 - “Peanut”
Triple 5 - 26TM123
Triple 5 - 26TM123
Got the same beast here too! Amongst others.
Havent yet heard anyone on it but theres always a chance, depends where you are I suppose and how much local cell interference there is going on.
As Ive found out all but channel 20 are unusable and even thats really noisy at times, channel 40 is the quietest usually 2 to 3 bars of noise at my location.
Its an exclusive band tho, so exclusive theres no one on it!
Btw, whats your little box of tricks on top of the Delta?
Yeah could be! My old Hygain 5 back in the 80's had a socket on the back marked selcall and at the time I didnt know what it did so I wrote to the manufacturers in the states in pen and ink -remember that stuff? long before mobiles and interwebs, got a letter back some weeks later informing me they no longer made radios and stated that it was for a selective calling unit to be fitted.
Headed out into the wild on sunday with the delta and a couple of antennas in tow.
After setting up on a hill I found that ch 20 and 40 were essentially clear,very little to no received cell activity.
No contacts made unfortunately but did get a few instances where static levels altered immediately after id called so possibly someone heard the calls. Seemed to be some voice traffic on ch20 but very back in the box and hardly discernible as such, might just have been my imagination.
Camera trained at the home based unit confirmed calls being received at 11 miles out so working as it should.
Beam antenna was useful as it easily "shot" between interference and could locate towers with it no problem.
If alls well weather wise, this sunday will repeat the exercise., hopefully will either qso or be received.
If anyone's interested that's not already watching it, I've been watching this Clarion 934mhz rig for a week on ebay and no one has bid as yet. Sometimes that means that the serious bidders are waiting until the dying seconds as usual:
https://www.ebay.co.uk/itm/153995834282
I was thinking about sticking a bid in but as it's not a UK radio, I've decided not to bother.
Headed out again today and set up away from the usual sources of noise.
With the co-linear up on the car ch 20 again was pretty much clear, 40 was totally so.
Carried out a few calls, had nothing back as usual, but phoned home to get a report as I was on air, signal was apparently clearer than the mobile at 11 miles distance. and signal meter over on max rx strength.
Next test is to set up the prs radios on 933 and get them to lock on to each other to get the contact and see how that all sounds.
Btw if anyone wants to set up a time and date to try and make a contact pm me.
That radio is apparently the one on the 934mhz club poster.The Collector wrote: ↑14 Jul 2020, 07:51 If anyone's interested that's not already watching it, I've been watching this Clarion 934mhz rig for a week on ebay and no one has bid as yet. Sometimes that means that the serious bidders are waiting until the dying seconds as usual:
