Avanti Sigma IV Rebuild.
- bigpimp347
Re: Avanti Sigma IV Rebuild.
i've got three of the original spacers all slightly bent where the basket had been lent up against a wall..
i've everything to straighten them out,
boiling water and a vice, a vice for weeks which works for around a day or so..
any ideas how to get them back straight ??
W8JI
- Ian1800
Interesting link Bob,
Personally I would never use the original Avanti spacers,
once they start to absorb water and it freezes its not long
before they snap
before they snap
i agree ian, replacing them is the best solution,
the later version sigma used plastic spreaders like a vector but higher quality.
W8JI
- Ian1800
Haven’t done much this weekend,
Bought the stainless steel nuts and bolts,
Assembled the bottom section and working
on the PL529 connection to connect to the
gamma match.
gamma match.
- Ian1800
Probably the next best to the Avanti Sigma 4!
but not sure what type of aluminium they used for it
but I do like the way they connected the ring.
- Ian1800
Another fault on the Sigma 4 is the gamma match bracket, which is made
out of 6061 T6 aluminium and tends to crack at the bolt holes then snap off.
I’ve made a copy out of softer 6082 T6 so it may stand the wind movement
a bit better…. I hope
looking nice ian
W8JI
- DX-Digger
- Call Sign: TM205
alexthegasman wrote:There used to be one i used to see right at the bottom of potteries way in Hanley, on the left, just before the island. Standing proud on the back of a house, I Haven't been that way for a while, wonder if it's still there??wheel bender wrote:These antennas and the breakers who dared to put them on their chimneys became landmarks that stood out among the tons of vertical aluminum around stoke. It's a real classic and will be nice to see pics of it back in the air where the other four in a perfect world should be.
No it is no longer there, it belonged to Charlie "NightOwl" I think he took his Ham ticket but then gave up radio.
I was always impressed with that sigma 4 everyone raved about them on the cb.
Hi Ian . Just curious , but how are you able to make a copy of a piece of an antenna like that ? Special machine , 3D printer ... ??Ian1800 wrote:I’ve made a copy out of softer 6082 T6 so it may stand the wind movement
Metal fatigue will do that to it at that point with tooing and froing over the years as that bit is stretched when bending it into shape meaning it's weakened. Tig-welding??? (is that the right type for aluminium) some supports across this point from the round bit to the straight bit about 3" long either side should help.
- Ian1800
I think the cracks are in there from new, this type of alloy doesn’t like to be bent
at sharp angels and fractures might be there from the factory especially if it was bent from cold,
I would of thought it would break at the first bolthole where the metal is thin but all the broken ones I have (and there’s quite a few) all of them break at the bend!
- Ian1800
I’ve decided to make my OS239 to gamma match connection similar to the grafter as I wanted to keep the original gamma match,
Wonder how yours has been performing over the past few years?
My original connector broke four times so I hope this will cure it.
- Phoenix
- Ian1800
Lucky find, brake pipe locking half nuts are the same size as a 3/8
Stud mount so I can get the gamma connection lower and near to
the original position so it wont alter the SWR to much.
I’m using Stainless steel P clips on the epoxy glass spacers.
