North Ayrshire - 453.825
- New User
I am using SDR Sharp with dsd plus, I can see there is DMR being used on 453.825 but there is no voice is only showing as data on cc7, I can hear every other DMR just not this frequency, has anyone been able to hear it ?
- New User
Re: North Ayrshire - 453.825
It could be just that, straight up data.. I have plenty of DMR Repeaters which spit out data. Try hooking up LRRP.exe (contained in the DSD+ folder) as it might be some location data, if it is you should see them pop up on a map.
- New User
Okay cool thank you, will definitely have a look at it.
- mr_h4ck3rm4n
- Call Sign: MM6SGZ
AFAIK its Ardagh Glass in Irvine , RAS system and used for data
HF
Ameritron 811, Yeasu FL2100
VHF/UHF
Icom IC-208H, Icom IC-2820
Jotron TR7550 VHF Air
Antenna
Data Interface
QRZ.COM
