bought sdr dongle from amazon advice to use plz?
- Call Sign: TV54
bought this from amazon is it simple to use just plugin and away you go or do you need to download software to go with it is it all easy to install and i take it as soon as software is installed and usb plugged in you can search for frequencies and use it like a scanner?
Re: bought sdr dongle from amazon advice to use plz?
You would be better keeping all your questions in 1 thread to keep it simple.
Best to research and look up YouTube etc for a lot of information
https://www.rtl-sdr.com/ Is a good starting point
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
