Digital frequencies Glasgow including tetra for aor dv10 ?
GlasgowTransmission
Call Sign: TV54
Post by GlasgowTransmission »
Hi I know we can’t listen to police but anyone have a aor scanner that can pickup tetra for other places or digital frequencies for aor dv10 ?
Metradio
Call Sign: G7HID
Re: Digital frequencies Glasgow including tetra for aor dv10 ?
Post by Metradio »
Newcastle Metro Trains
Nottingham Trams
London Tube Network
Northern Ireland Ambulance & Fire
All reported in the clear..
Mike
neil57uk1
Post by neil57uk1 »
Plus Dublin Luas Tram Network
Glasgow Underground (think its clear)
Maybolelistner
Call Sign: MM6AAM
Post by Maybolelistner »
Daft question but does in the clear mean you can listen to these organisations on this radio? Fee free to pm me rather than posting
Metradio
Call Sign: G7HID
Post by Metradio »
Maybolelistner wrote: 25 Feb 2021, 14:57 Daft question but does in the clear mean you can listen to these organisations on this radio? Fee free to pm me rather than posting
It is no secret, unencrypted (in the clear) Tetra can be received by the AOR DV1 and DV10, also by various dongles that can be plugged into a PC..
Mike
Maybolelistner
Call Sign: MM6AAM
Hi Mike ,
Have sent you a pm hope this is okay!
Metradio
Call Sign: G7HID
Post by Metradio »
Will reply to your PM here, I am no expert on PC dongles so you would do better asking your questions on here as you would reach a wider group of expertise on the subject..
Mike
Maybolelistner
Call Sign: MM6AAM
Are you any good with the set up? And also with those names you mentioned above can you receive these nationwide? Just trying to work out if it’s worth my
While trying to pursue this side of the hobby
Metradio
Call Sign: G7HID
Post by Metradio »
I had a dongle years ago but migrated to digital scanners that are not tied to a PC and can run stand alone, also a couple of scanners I use are portable - which you can't easily do with a dongle.
Apart from the Northern Ireland example the other examples are limited to their local are and in the case of London Underground the signal is not receivable very far from the tube stations and overground lines..
Mike
scottyboy
Post by scottyboy »
With tetra and other radio networks in the uk none are nationwide, only radio network nationwide is airwave the encrypted emergency service network.
Tetra infrastructure is very expensive so no point in say London Underground network having base stations in Manchester or Glasgow etc.
Most if not all private networks are clear and limited range from where they operate.
If near the coast it’s been reported some off shore wind farms use tetra. But not all.
Some onshore ones also use it also but ones around me still use analog.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
abyzz
Post by abyzz »
Anyone know if the new "Emergency Services Network" has gone live in the UK yet?
I know that here in NI the Fire and Ambulance has been on Tetra in the clear for a long time now, but recently some of the Ambulance stuff has disappeared ( namely the Rapid Response units ) and I was wondering if they had migrated to the new system or had just changed to an encrypted Tetra instead?
TIA
scottyboy
Post by scottyboy »
The new ESN is still in construction / testing.
I can see the network on my mobile when I do a manual network scan.
Certainly here in Scotland the cops still use airwave but are / have also been issued with tablet / PDA but not sure if that’s on ESN or another network at present
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Mototrbo2020
Post by Mototrbo2020 »
abyzz wrote: 05 Jun 2021, 15:07 Anyone know if the new "Emergency Services Network" has gone live in the UK yet?
TIA
Still a year away I would say, they are now replacing all the Huawei equipment they spent years fitting.
