AM & FM to be killed off by 2016
The place to discuss long distance TV and Radio Reception. Equipment, Antennas and anything to do with the art of DX.
Sparkgap
Call Sign: G1BED
Re: AM & FM to be killed off by 2016
Post by Sparkgap » 07 Sep 2018, 18:40
Problem is DAB in many cases can end up worse than FM, at least you can make out FM under poor signal conditions while DAB gets the digital hiccups! With more stations being crammed onto the multiplexes I know a number of broadcasters have dropped bit rates and in some cases even gone to mono!
As an aside, I was visiting an irish broadcast station in the 80s where they were planning to try AM stereo (using ISB I think) and had brought an AM stereo receiver over from the US. The receiver processing was so good that it even made ordinary AM stations sound FM quality.
MrWeetabix
Call Sign: 26TM175
Post by MrWeetabix » 10 Sep 2018, 09:53
Stereo AM would have been quite the feat.... :thumbup:
grafter
Post by grafter » 10 Sep 2018, 22:00
Have a listen to this, WION Ionia, MI. The stream is taken off air from their AM stereo signal on 1430kHz.
http://i1430.com/index.html
albrecht
Post by albrecht » 13 Dec 2018, 11:44
Longwave and AM radio receives best here, FM needs a good antenna, ditto for DAB as well as DAB eating up rechargeables. You have to be selective what you hear whereas you can have AM/LW on all day.
