I am in the market for a new scanner and going digital. I think I've narrowed it down to these two but would like some advice on which ones the better one and why.
Many thanks
Mox
Whistler TRX2 or AOR DV1
- Call Sign: G0CRB
Re: Whistler TRX2 or AOR DV1
I can't answer for the TRX2. However, a couple of years ago I bought a DV1, and it does make life a litter easer as the DV1 does most things for you, When it finds the channel it and if it's set to Auto it will work out the correct colour code and most of the other info for you like DMR, Yeasu, Icom D-Star etc etc. So for me, I would recommend the DV1
