Watts into amp
- NightProwler
- Call Sign: 163TM186
Watts into amp
Just wondering really if it is safe to pass 100 watts through an amp that is not switched on? I done it by accident, Everything is ok but it got me thinking
Re: Watts into amp
I wouldn't
Not sure what amp it is , but mine is a valve type and the i/p gets fed through the relay when it's off . Not sure how much the relay will handle , but 100W would be pushing it in my case I think .
- Buick Mackane
Re: Watts into amp
100 Watts on 11m ? Please provide proof from ofcom that you are entitled to run such power on 11m otherwise i will have no option but to remove you from the forum, You have 5 minutes to comply
- NightProwler
Re: Watts into amp
I would never dream of putting out 100 watts, 200 yes. Ofcom you know where I am and you will have about as much luck as the TV licence goons have when they come calling
Cheers though dudes
Cheers though dudes
- Transwarp
- Call Sign: Viper
Re: Watts into amp
"Its no bluff! By the way - may I see your TV licence while I'm here?"Buick Mackane wrote: ↑08 Apr 2024, 11:12 100 Watts on 11m ? Please provide proof from ofcom that you are entitled to run such power on 11m otherwise i will have no option but to remove you from the forum, You have 5 minutes to comply
Re: Watts into amp
I applied for a job with them last month . Lucky for you guys I didn't get it , as I've got all your details noted down
- Buick Mackane
Re: Watts into amp
The Spanish branch El Ofcomo
