How to stream SDR over the internet ?
I have a cheap SDR and i'd like to stream it over the net. Does anyone know how or could give more info. I noticed London don't have anyone streaming a SDR over the net so i'd like to be the first.
Re: How to stream SDR over the internet ?
https://www.openwebrx.de/ openwebRX would be a suitable starting point, you will need a host machine to run the server from, this can be even done with a raspberry pi computer.LondonCbRadio wrote: ↑06 Aug 2023, 20:35 I have a cheap SDR and i'd like to stream it over the net. Does anyone know how or could give more info. I noticed London don't have anyone streaming a SDR over the net so i'd like to be the first.
If I may make a request, please add support for the 11m, 2m/70cm and pmr-446 band.
73 and good luck.
- Call Sign: redacted
Other simple options include Spyserver (part of the sdrsharp releases, https://airspy.com/download/) and Globaltuners (https://www.globaltuners.com/)
I stream on YT if I need.
Whilst globaltuners is a viable option, I believe that whilst it can be used with an SDR, it was originally intended for use with traditional receivers, hence the lack of spectrum display and single frequency. So in my view I don't think it would be an appropriate solution for the SDR.milly wrote: ↑07 Aug 2023, 08:32 Other simple options include Spyserver (part of the sdrsharp releases, https://airspy.com/download/) and Globaltuners (https://www.globaltuners.com/)
Spyserver on the other hand would be another great and suitable solution.
73.
11meter and pmr446 will be priority.dc260 wrote: ↑06 Aug 2023, 22:38https://www.openwebrx.de/ openwebRX would be a suitable starting point, you will need a host machine to run the server from, this can be even done with a raspberry pi computer.LondonCbRadio wrote: ↑06 Aug 2023, 20:35 I have a cheap SDR and i'd like to stream it over the net. Does anyone know how or could give more info. I noticed London don't have anyone streaming a SDR over the net so i'd like to be the first.
73 and good luck.
- Call Sign: G4RMT
I suppose it might be people report it to OFCOM and they get the ISP to block it. They certainly do that when people try to stream airband. I wouldn't have thought it worth it on CB or PMR446 as they're not controlled services, and are a mess anyway? They could of course if the content was questionable.
Can you provide some examples of this? The G0XBU webSDR has provided both PMR-446 and Airband reception for many years now.paulears wrote: ↑08 Aug 2023, 11:44 I suppose it might be people report it to OFCOM and they get the ISP to block it. They certainly do that when people try to stream airband. I wouldn't have thought it worth it on CB or PMR446 as they're not controlled services, and are a mess anyway? They could of course if the content was questionable.
http://81.174.147.103:8901/
- Call Sign: G4RMT
Interesting - I've discovered quite a few now doing it - but the power that was used appears to be section 48 of the Wireless telegraphy Act - which prevents you passing on what you have heard from stations other than broadcasting. I can't find any prosecutions, but that law section is still active and was what they used in the past. Perhaps they've changed tack as OFCOM now are once again administering aviation radio - which was previously contracted out to the CAA. Maybe the CAA hated it and stopped it, but OFCOM are more 'loose'.
I think you're stuck in the past my friend. Things moving very fast now days.paulears wrote: ↑08 Aug 2023, 16:59 Interesting - I've discovered quite a few now doing it - but the power that was used appears to be section 48 of the Wireless telegraphy Act - which prevents you passing on what you have heard from stations other than broadcasting. I can't find any prosecutions, but that law section is still active and was what they used in the past. Perhaps they've changed tack as OFCOM now are once again administering aviation radio - which was previously contracted out to the CAA. Maybe the CAA hated it and stopped it, but OFCOM are more 'loose'.
- Call Sign: G4RMT
Only since OFCOM took it back from the CAA, but I take your point.
I've got ubuntu if anyone can give me a step by step guide for openwebrx that would be great as i'm not that good with computers.
Openwebrx saying no sdr devices. I'm using ubuntu.
Turns out i have a fake SDR it's a cheap blue one i got from ebay.
Do make sure you have the up to date drivers installed for it and not the default ones.
