Hi All,
A new information release from NATS (AERONAUTICAL INFORMATION CIRCULAR P 047/2023) has appeared today and gives details for a UK-wide VHF frequency available for use in class G airspace below 2000 ft. It is referred to as the "VHF Low Level (LL) Common Frequency" and can be found at 130.490 (channel) or 130.4916MHz frequency.
Enjoy!
New VHF airband frequency allocated to low-level comms...
- Call Sign: G7RUX
Re: New VHF airband frequency allocated to low-level comms...
130.4900 has been in use for over 2 years for Low Fly U.K. Wide
- Call Sign: G7RUX
Indeed it has been used as a trial but this circular now makes the use permanent.
- Call Sign: G0CRB
I added that frequency to my scanner yesterday and found it quite active.I'm in the Midlands.
