Amateur Radio DX Contacts / Reports - April to June 2023
Buick Mackane
Moderator
Moderator
Post by Buick Mackane »
Worked the following countries on 15m last weekend during the contest.
Morocco
Turkey
USA
Canada
And a load more in Europe.
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Re: Amateur Radio DX Contacts / Reports - April to June 2023
Post by MrWeetabix »
10m is waking up.....
Buick Mackane
Moderator
Moderator
MrWeetabix wrote: 10 May 2023, 08:37 10m is waking up.....
I'll take a listen craig, It's been a tad quiet the last month or so
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Not a bad day in the end. Sure, its all FT8 (I know I know!) but its not bad for being at work. The mode allows me to play radio whilst I do my day job working from home :-)
Samalex
Call Sign: MM0
Post by Samalex »
was ok here is what did on the 8th
Call Sign: Lemmy
Post by ch25 »
Since 1st of april: 3D2LYC, DX0NE, CO0RRC, E51WEG, T30UN, 4W1A, E51CIK, VK9WX, XF3O and some more.
SSB only, most on 10m
MrWeetabix
Admin
Admin
Call Sign: 26TM175
I really should make an effort on 10m voice. I don;t think I have any logged at all since maybe lockdown now
MrWeetabix
Admin
Admin
Call Sign: 26TM175
The Imax tunes and works rather well on 15m.... I don't recall ever working so many stations in Japan in one session!
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Thre is deffo some Grey Line prop at work here.... :ugeek:
MrWeetabix
Admin
Admin
Call Sign: 26TM175
2M is running well today, also had some EU stuff on 70cm. Not bad for my vertical-only setup here :-)
Southern England, Scotland, Denmark and Germany mainly worked on 2m
Bagged Southern England, Denmark and Northern Ireland on 70cm
Antenna is GP-9 2/70 vertical with 30w :-D
MrWeetabix
Admin
Admin
Call Sign: 26TM175
2m is open, has been most of this week to be fair. Happy to see I can hold my own with just a high gain vertical and 30w :-)
Call Sign: Lemmy
Post by ch25 »
In my area 2/70 dead as usual :)
