What scanners are people using
Hey all I've got a 125xlt witch is brilliant. I'm curious what are others using or what's your recommendations for scanners... I've been looking at some okder stuff as been told some can receive other bands or have a wider range.
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
Baofeng UV-9R
uniden ubc125xlt
Moonraker M10
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
Baofeng UV-9R
uniden ubc125xlt
Moonraker M10
Re: What scanners are people using
R8600 since a few weeks.
BCT15x before.
BCT15x before.
- Tin soldier
NotaRubicon just did a video on one .
I thought they were pretty obsolete these days, especially in UK ???
- Call Sign: G7RUX
Icom R6, R30, Yaesu VR5000 and sometimes the general receive part of an Icom ID52E or a Yaesu FT-2D here.
Uniden 3500, 3600, 325p2.
Also have several Mototrbo handhelds that are programmed up to scan.
- NightProwler
- Call Sign: 163TM186
I use an old AOR 3000A and a Yaesu FRG9600. Love them
- Call Sign: G0CRB
I have several Scanners, been using them for years.... However, a couple of months ago I bought a AOR AR-DV1 and I must say it's the best scanner that I have owned in 40 years. No need for computers, In its auto Mode will decode so many digital modes Fusion.Dstar DMR to name just a few.Plus it has USB and LSB , Oh yea and its frequency coverage on the UK model is great.
AOR AR2002, AOR AR DV1, YAESU 9600, and a Fairhaven RD 500. I'm considering selling the Fairhaven or swapping for a Whistler TRX2. Jury's out on that one!!
You can never have enough radios!
- Whisky1
£99 for a sdr play....best receiver I have bought cost wise....it's not a scanner but it does exactly what I need.
- Call Sign: G7RUX
I have an AR3000A n my bench at work connected to a white stick colinear on the roof of the building which works pretty well. I should improve the feeder as it’s fairly long but it works well got the intended function.
Uniden 125-xlt and Grecom PSR-295. The latter seems to suffer from less from interference on VHF low band but there's nowt on there anyway
- Auldgeek
- Call Sign: GM0BRJ
Currently using an Icom IC-R8600
Auldgeek - Drew
I'm new to scanning but I use a handheld Uniden 125xlt with a Diamond D130 discone- out the back on the shed.
