YAESU frg9600 ...
DETECTORIST
YAESU frg9600 ...
Post by DETECTORIST »
Just dug this out of my cuberd after some years. Can someone tell me what the antenna socket on the left hand side is used for the one on the right says antena.but no label on the other one
14CS06
Re: YAESU frg9600 ...
Post by 14CS06 »
Hello
Originally there is no antenna socket on the left side
You have to open to see where the plug is connected
DETECTORIST
Connected to the silver box. That has vty1u103 label on it.w
DETECTORIST
for some reason i cannot send another atatchment
DETECTORIST
DETECTORIST
Ok that's the silver box you can see the coax attached.
dcwuk
Post by dcwuk »
I believed that it is an add-on TV IF module for watching TV. and its likely to be analogue.
Then again I may be completely wrong. :|
NightProwler
Call Sign: 163TM186
Post by NightProwler »
The silver box is supposed to be there. The extra SO239 socket suggests it's had the HF mod done to it.
14CS06
Post by 14CS06 »
hello
viewtopic.php?t=18954
DETECTORIST
ok thanks will check the mods out.
