Sirio Performer 5000 or Sirio HP400 Antenna
Air
Post by Air »
Hi everyone.
Does anyone use the Sirio Hp4000 or the Sirio Performer 5000 mobile antennae.
If so which is the best for CB, like everyone am looking for distance.
Will not be using high power as its not allowed.
In relation to either of the above, they come in mag mount, which I think
is the best option for me, they are also available in through / fixed mount,
does the through / fixed mount type require an RF ground, I am fitting on the
roof of my car so would rather not have to add a ground wire.
If no RF ground is required, then is there any technical advantage to a mag
mount vs a bolt on type antenna, as I could add a bracket to the roof rack
to use a bolt on type if it was going to provide better performance.
I appreciate your comments, thanks in advance.
Tin soldier
Re: Sirio Performer 500 or Sirio HP400 Antenna
Post by Tin soldier »
You've already asked this .
https://www.transmission1.net/viewtopic ... 69#p554569
And mentioned getting an amplifier πŸ‘πŸΌπŸ˜‰
Air
Post by Air »
Tin soldier wrote: ↑25 Feb 2023, 08:14 You've already asked this .
Forgot about that post, answers my question too.
Air
Re: Sirio Performer 5000 or Sirio HP400 Antenna
Post by Air »
@Tin soldier I will avoid the amp, there is a lot of harrasment here
now since covid, the powers that be got used to dictating, they check
everything on us natives, so amp would definitely result in trouble.
Tin soldier
No worries Air. πŸ‘πŸΌ
lambrettadave
Call Sign: TM455
Post by lambrettadave »
If you do buy a big sirio.... Make sure you get a genuine sirio Mag mount with it as some places offer inferior types that may or may not be up to the job
Air
Post by Air »
lambrettadave wrote: ↑28 Feb 2023, 00:47 If you do buy a big sirio.... Make sure you get a genuine sirio Mag mount with it as some places offer inferior types that may or may not be up to the job
Thanks for that pointer, I will query if the original mount is offered.
