Bloody SWR meters
NightProwler
Call Sign: 163TM186
Bloody SWR meters
Post by NightProwler »
Hey all. I have two SWR meters here or should I say SWAAAAAR meters, One is a Welz SP-15M and the other is a Avair AV-600 but they both give different readings. With a dummy load in they both show a perfect SWR, The needle does not move so I guess they are ok. It's not a huge difference but on 26.000MHZ for examplle one shows 1.6 and the other 1.9. So which one do I believe?
Rich :thumbup:
Call Sign: Lemmy
Re: Bloody SWR meters
Post by ch25 »
It is simple to verify.
Grab 100 Ohm resistor and measure SWR. Should be 2:1
Than you will know your meter accuracy.
NightProwler
Call Sign: 163TM186
Ahhhh I remember reading that somewhere before. Nice one I will give it a go :thumbup:
ChubbyChops
Call Sign: 26TM773
Post by ChubbyChops »
Connect them in reverse and they should read the same if properly calibrated.
Tin soldier
Post by Tin soldier »
ChubbyChops wrote: 06 Jan 2023, 18:48 Connect them in reverse and they should read the same if properly calibrated.
👍🏼 Beat me to it .
NightProwler
Call Sign: 163TM186
Interesting video, Never knew you could do that. Cheers dudes :thumbup:
paulears
Call Sign: G4RMT
Post by paulears »
Cheap meters are simply indications, not remotely accurate, but I suppose there's no real need for most users.
NightProwler
Call Sign: 163TM186
Well it's looks like the Welz meter is accurate and the Avair is not. Learn something everyday on here :D
Edd200sx
Post by Edd200sx »
I use an lp100a and get cross examined by people using zetagi
Meters. Quite funny really
DELETE MY ACCOUNT
paulears
Call Sign: G4RMT
Post by paulears »
I suppose any cheap meter is going to suffer from using two different component chains to do the measuring, which explains why the very expensive Bird meters do VSWR measurement by having one small plug in element with the measuring components that you physically turn through 180 degrees to do the forward vs return measurements. Effectively working like swapping the ins and outs around.
Spooky
Post by Spooky »
I'm completely new to radio and have read about and watched loads of vids on SWR meters recently.
I just receive at the moment on a discone, but would need a meter when the CB antenna goes up to transmit.
I would like at a later date to maybe get more into Amateur radio (license) so I ended up getting a Nissei DG 503max.
This is clearly overkill for a simple CB setup I understand, I just wanted to future proof myself, if I end up transmitting on the discone - at non CB frequencies that would need SWR adjustment.
Just my 2 cents from a new guy.
