Diamond x30 / x50 on 446
hey all, has anyone got any experience of using an x30 / x50 on 446? Im in the market for a dual bander but would like 446 coverage too so any advice welcome. cheers!
- Tin soldier
Re: Diamond x30 / x50 on 446
viewtopic.php?t=48032
None, but I've been thinking of getting the Sirio mentioned in the last post in the link for homebase. PMR only though.
- chazwozza
- Call Sign: 26CD172
Used a 510 on 446 ok
cheers both, ive ordered an x30 so will report back when i get it up. i have a nano vna so will do a sweep and see what it looks like. chatting to a few of the locals they seem to use them on 446 and think they are alright so fingers crossed!
- Call Sign: 26DG01
It should work very well. Also, the advantage of using low power (500mW ERP) is that effects of SWR mismatch will be less damaging. Recall, SWR is a ratio. On the whole, a 3:1 mismatch at 500mW will have significantly less reflected power than a similar mismatch at 5W.
Sent from my GP300 using DTMF
- chazwozza
Not really used it to be fair
- CookieRaider
- Call Sign: M0RMO
All the 'white stick' antennas have a decent wide coverage at UHF any in the range will do what you want, from experience though some are manufactured better than others. I've had cheap clones that worked but build quality showed after a couple of years, just replaced a WATSON W-300 clone as the base had broken after 2 years, put up a DIAMOND V-2000 these pics might give you some reassurance
Winner of the coveted 'In Before The Lock' competition 07 Jan 2013
Winner of the coveted 'In Before The Lock' competition 24 June 2013
inaugural champion of the coveted "Putting sex before trivial internet games" award November 2013
x30 gives me an SWR of 1.7 with 40W
26TM069
M3UBO-----> 2E0FML---->2E0PUC
- Call Sign: M0DCD
A lot of the commercial antennas for the US market do perform up to 450MHz, so should have acceptable performance on 446MHz.
SWR shouldn't change with power, unless it's been overloaded and something is breaking down.
- Call Sign: G4RMT
Earlier on, somebody asked about pmr446 in suffolk. Plenty of space, hardly anybody using it for anything other than shop storeroom and restaurants yelling for orders. Cb, ham and pmr446 hobby stuff is very sporadic. The local ham repeaters can have days with nothing!
D30 antennas are not horrible at 446 and worth experimenting with. They do marine reasonably well too.
