Yaesu FT-840 help needed
Hi guys i have a Yaesu 840 and when i turn power up above a certain level around 30 watts sometimes the tx power goes to 0 as i'm transmitting. SWR is fine and tried with a dummy load and still happening. It is a intermittent problem. Does anyone have any idea what could be causing it ? Also the signal meter on FM isn't sensitive enough is there anything i can change to make it better ? Everyone gives the same signal more or less unless they are close by me.
- Buick Mackane
Re: Yaesu FT-840 help needed
Not familiar with the radio in question but i'd suspect a dry joint on the PA board, And there should be an adjustment for the FM RX meter
Nice radio but i've come to the conclusion there are too many design flaws. The Radio is now blinking and only stops when i go to the lower hf bands. Shame as i love the meter on this radio.
- Buick Mackane
Just looked online, It's an older model, So not loaded with SMT and processors, So chances are it shouldn't be too tough to repair, I guess from looking at it it dates from the 90's, So probably needs a few electrolytic capacitors replaced.
Thanks mate i'll keep trying until i get there.
- Buick Mackane
I Dunno if nick black spirit repairs amateur gear, Only one way to fine out, Ask him
- Auldgeek
- Call Sign: GM0BRJ
He doesn't unfortunately. Dave Woods or Geoff Castle would be my choice,Buick Mackane wrote: ↑11 Sep 2022, 13:17 I Dunno if nick black spirit repairs amateur gear, Only one way to fine out, Ask him
Auldgeek - Drew
Anyone have any idea on how to make the meter more sensitive ?
Maybe meter is lazy because low signals incoming? Did you measure RX sensitivity?
Proper way to do it:
Or use external transmitter and try to adjust.You do not have the required permissions to view the files attached to this post.
Maybe i didn't explain myself clearly. On my other rigs there is 3 s points difference between 2 people,now the same people on my yaesu 840 give me the same signal or maybe a needles width difference. This only happens on fm.
So it sounds like FM path issue, not s-meter itself.
