CRT 7900V software? S meter setting.
- Vapor
- Call Sign: dipstick
Hi to all
I have just purchased the CRT 7900V out of interest i wanted to see if the service menu was still the same as the old SS-7900 and its not, no service menu shows up holding menu and mode while turning on power. not that i am that worried about that but frequency adjustment could be usefull if your not close enough, luckily mine is very close.
But my real gripe is the new 7900V software does not contain the S meter RSI adjustments any more. i have a signal gen by marconi and like to set the S meter as per sig gen. but now i cant as no longer in the software.
the S meter readings are quite a bit off and annoying.
So if anyone has any idea why its no longer available i would be interested, or if they have a way to get into service menu?
Matt
Matt
CB dipstick
73's and Good DX people!
- JibberJabber
Re: CRT 7900V software? S meter setting.
It annoys me too… Unfortunately I Don’t know how to do it … sorry.
J
J
- Auldgeek
- Call Sign: GM0BRJ
Yeah, annoys me too. I setup my 7900 using the RSI adjustments and expected same with the 7900V.
There will be s meter calibration adjustments, but until we see the full engineering menu and what each menu item does, we're a bit screwed.
As it is, the s meter is way too high.
Auldgeek - Drew
- 14CS06
Hello
New pcb different from old
- Vapor
Was such a nice feature the RSI adjustments, Think i will wait a few months and if nothing comes out about how to adjust i will get rid of it. I have also sent an email to CRT asking why its not in the new 7900V software. So if any one reads this they might also ask them the same question as i would think features added not taken away with new version's.
A shame really as it seems quite good apart from the silly S readings.
CB dipstick
Crt won’t reply they are pretty much the worst company on earthVapor wrote: ↑23 Aug 2022, 09:30 Was such a nice feature the RSI adjustments, Think i will wait a few months and if nothing comes out about how to adjust i will get rid of it. I have also sent an email to CRT asking why its not in the new 7900V software. So if any one reads this they might also ask them the same question as i would think features added not taken away with new version's.
DELETE MY ACCOUNT
- Vapor
This is how you enter service mode
CRT SS 7900V TURBO - SERVICE MODE:
Step 1: Press and hold MENU and MODE while you turn the radio ON. All LCD segments will show for around 2 seconds.
Step 2: Within this 2 second window, release the MENU and MODE buttons, and quickly press these keys, one after another (within the 2 second window): RB, NB, SCAN, MEM, EMG.
The radio will enter Service Mode.
Everything that is adjustable in the radio is done in this menu... The options in the Service Mode menu are:
CH-01 CH-01
CH-02 CH-02
CH-03 CH-03
CH-04 VCOFRQ
CH-05 BFOFRQ
CH-06 TX-IQ1
CH-07 TX-IQ2
CH-08 TX-IQ3
CH-09 FMPOWH
CH-10 FMPOWL
CH-11 FMRSSI
CH-12 FMMOD
CH-13 FMTONE
CH-14 CTC
CH-15 DCS
CH-16 AMPOWH
CH-17 AMPOWL
CH-18 AMRSSI
CH-19 AMMODL
CH-20 AMMODH
CH-21 AMTONE
CH-22 ULPOWH
CH-23 ULPOWL
CH-24 USB PA
CH-25 LSB PA
CH-26 USBPWL
CH-27 USBPWH
CH-28 BPFUSB
CH-29 BPFLSB
CH-30 USBTON
CH-31 LSBTON
CH-32 RX BPF
CH-33 TX BPF
CH-34 UL SQL
CH-35 UL SQH
CH-36 AF SQH
CH-37 AF SQL
CH-38 ASQ H
CH-39 ASQ L
CH-40 AF RS1
CH-41 AF RS3
CH-42 AF RS5
CH-43 AF RS7
CH-44 AF RS9
CH-45 AFRS12
CH-46 UL RS1
CH-47 UL RS3
CH-48 UL RS5
CH-49 UL RS7
CH-50 UL RS9
CH-51 ULRS12
CH-52 RFG
CH-53 SQTH
CH-54 ASQTH
CH-55 WXFRQ
CH-56 WXSQ0
CH-57 WXSQ1
CH-58 VBAT
CH-59 VER100
Really need a service manual to find out what each adjustment does.
CH-01 CH-01
CH-02 CH-02
CH-03 CH-03
CH-04 VCOFRQ
CH-05 BFOFRQ
CH-06 TX-IQ1
CH-07 TX-IQ2
CH-08 TX-IQ3
CH-09 FMPOWH
CH-10 FMPOWL
CH-11 FMRSSI
CH-12 FMMOD
CH-13 FMTONE
CH-14 CTC
CH-15 DCS
CH-16 AMPOWH
CH-17 AMPOWL
CH-18 AMRSSI
CH-19 AMMODL
CH-20 AMMODH
CH-21 AMTONE
CH-22 ULPOWH
CH-23 ULPOWL
CH-24 USB PA
CH-25 LSB PA
CH-26 USBPWL
CH-27 USBPWH
CH-28 BPFUSB
CH-29 BPFLSB
CH-30 USBTON
CH-31 LSBTON
CH-32 RX BPF
CH-33 TX BPF
CH-34 UL SQL
CH-35 UL SQH
CH-36 AF SQH
CH-37 AF SQL
CH-38 ASQ H
CH-39 ASQ L
CH-40 AF RS1
CH-41 AF RS3
CH-42 AF RS5
CH-43 AF RS7
CH-44 AF RS9
CH-45 AFRS12
CH-46 UL RS1
CH-47 UL RS3
CH-48 UL RS5
CH-49 UL RS7
CH-50 UL RS9
CH-51 ULRS12
CH-52 RFG
CH-53 SQTH
CH-54 ASQTH
CH-55 WXFRQ
CH-56 WXSQ0
CH-57 WXSQ1
CH-58 VBAT
CH-59 VER100
CB dipstick
Hi,
Bit off topic but is that finned heatsink inside the new version factory fitted?
- Vapor
yes it is factory fitted
CB dipstick
I would have lost that bet! At least will keep the caps nice and warm
- delboyonline
I have created a video showing all of the Service Menu items on the new CRT SS7900V Turbo
https://youtu.be/qIEBkHEAv3c
More on the blog as well.... https://delboyonline.blogspot.com/2022/ ... -menu.html
ch40 to ch51 are probably sensitivity and a meter adjustment
Note. Probably
Note. Probably
DELETE MY ACCOUNT
- delboyonline
Yep that's correct.
- Vapor
Ok so i went into the service menu to adjust menu 37 AF-SQL also menu 36 AF-SQH i now have a sensitive SQ that lets weak signals through. I found factory settings on weak signals kept the SQ cutting in and out. now its sweet.
I then proceeded to the S meter settings. Menu 40 to 45 the FM signal settings.
All the above settings were changed using my Marconi signal generator ( YOU CAN NOT DO THIS WITH OUT ONE SO DON'T TRY)
First of all you need to find the setup Frequency which is 27.420 fm you can not set up on any other frequency.
If you key the Mic it shows you the current settings. if you push the VFO knob it will change the settings to what it hears now so don't do it with out a signal generator.
I now have a much better radio, the SQ opens nicely for weak signals and the S meter confirms what i have on other radio's nicely.
CB dipstick
